Home » Modeling » TMF (Xtext) » Scope for starting element
Scope for starting element [message #922871] Tue, 25 September 2012 08:16 Go to next message
my grammar starts with an element like
AllAnimals: Horse | Dog | Fish | Bird;
to edit different types.
Nevertheless, sometimes the sub type is known in advance, e.g. the editor should be limited to the 'Dog' element.
Is it possible to tell the editor to change the possible editable types to sub elements only?
Can this be achieved with the scope provider?
Gaspar
Re: Scope for starting element [message #924798 is a reply to message #922871] Thu, 27 September 2012 02:09 Go to previous messageGo to next message
Is this decision static (a certain place in the grammar) then you could introduce a special parsing rule for that.
you are mentioning the scopeprovider
this is for cross refs only. you did not post anything of the rest of your grammar.
so it is really hard to give any advice.
it would be nice if you could post a complete (please simplify it) grammar and an example model
~Christian
Re: Scope for starting element [message #924839 is a reply to message #924798] Thu, 27 September 2012 03:03 Go to previous messageGo to next message
Hi Christian,
a simplified Xtext describing the problem:
Horse: {Horse} "Horse" "(" weight=INT "," height=INT ")";
Dog: SmallDog | BigDog;
SmallDog: {SmallDog} "SmallDog" "(" weight=INT "," name=STRING ")"
BigDog: {BigDog} "BigDog" "(" description=STRING "," age=INT ")"
Fish: {Fish} "Fish" "(" maxDepth=INT "," lenght=INT "," name=STRING ")"
Bird: {Bird} "Bird" "(" color=STRING ")"
With this definition, its possible to edit s.th. like:
Horse (100, 150)
SmallDog (10, "Hektor")
Bird ("blue")
But there are cases where the type is restricted, e.g. "Dog" (and not "AllAnimals").
How can I start the editor then to allow only dog like entries, i.e. for example:
SmallDog (5, "Hasso")
BigDog ("nice and friendly", 5)
but not
Fish (200, 20, "Nemo")
Gaspar
Re: Scope for starting element [message #924869 is a reply to message #924839] Thu, 27 September 2012 03:38 Go to previous messageGo to next message
Hi you still have no place in your grammar where you want to use your
Dog and/or AllAnimals
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Scope for starting element [message #924901 is a reply to message #924869] Thu, 27 September 2012 04:15 Go to previous messageGo to next message
sorry but my descrpition was not clear enough.
My simplified xtext definition:
grammar de.example.xtext.Animals with org.eclipse.xtext.common.Terminals
generate animals "h**p://www.example.de/xtext/Animals"
SmallDog: {SmallDog} "SmallDog" "(" weight=INT "," name=STRING ")";
BigDog: {BigDog} "BigDog" "(" description=STRING "," age=INT ")";
Fish: {Fish} "Fish" "(" maxDepth=INT "," lenght=INT "," name=STRING ")";
Bird: {Bird} "Bird" "(" color=STRING ")";
With this definition, it is possible (and wanted) to edit a single line only.
E.g.
Horse (100, 150)
or
But sometimes it has to be restricted. In the usecase the sub type ("Dog" or "Fish") may be known.
I could write a validator to check for the supported type. But then, I have to adjust proposal, quickfix etc., too.
And the final grammar is a lot more complex.
It would be more easy to somehow (how?) change the starting behaviour to start with "Dog" instead of a super type "AllAnimals".
Is this possible?
Gaspar
[Updated on: Thu, 27 September 2012 04:17] by Moderator
Re: Scope for starting element [message #924913 is a reply to message #924901] Thu, 27 September 2012 04:19 Go to previous messageGo to next message
Hi I still want know if you have a place like
DogWorld: "test" dog=AllAnimals. What is the context/criteria for the
"sometimes" you do not want all animals
Re: Scope for starting element [message #924937 is a reply to message #924913] Thu, 27 September 2012 04:49 Go to previous messageGo to next message
there is no other place like
(For now, there are no needs to consider this (code generation does not matter for this).)
The context criteria is only known at runtime (before starting the editor).
At runtime, the program determines a (sub) type (i.e. "AllAnimals" or "Dog" or "SmallDog" etc.).
The user then may open the editor to edit/modify this (sub) type.
So, in some cases, the user must not be allowed to enter a wrong kind of animal/type.
Gaspar
Re: Scope for starting element [message #924954 is a reply to message #924937] Thu, 27 September 2012 05:01 Go to previous messageGo to next message
Hi guess then it is hard to do this.
You could try to adopt content assist.
But you would need checks anyway
Re: Scope for starting element [message #924981 is a reply to message #924954] Thu, 27 September 2012 05:28 Go to previous messageGo to next message
You could try to overwrite MyDslAntlrParser#getDefaultRuleName or
#doParse or something to leverage some contextual information. Most
likely you'll have to customize XtextResource#update(int, int, String)
and #doLoad, too.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 27.09.12 11:01, schrieb Christian Dietrich:
Re: Scope for starting element [message #924995 is a reply to message #924981] Thu, 27 September 2012 05:47 Go to previous messageGo to next message
Hi Sebastian,
this sounds promising.
A first try in overwriting MyDslAntlrParser#getDefaultRuleName
worked fine and exposed error messages for wrong types.
Only the code completion still knows about the "wrong" types
and still makes wrong suggestions.
Gaspar
Re: Scope for starting element [message #925113 is a reply to message #924995] Thu, 27 September 2012 07:27 Go to previous messageGo to next message
Hi Gaspar,
please try to hook into
MyDslParser.getFollowElements(AbstractInternalContentAssistParser)
in your UI plugin.
Sebastian
Am 27.09.12 11:47, schrieb Gaspar Din:
> Hi Sebastian,
> Thanks
> Gaspar
Re: Scope for starting element [message #925126 is a reply to message #924995] Thu, 27 September 2012 07:52 Go to previous message
Hi Sebastian,
yes, that's it.
Overriding the ContentAssistParser allows switching to the right type proposal.
Thank you
Gaspar
Previous Topic:Where is spell checking configured?
Next Topic:NPE in serializer
Current Time: Sun Jul 20 06:03:30 EDT 2025
Powered by FUDForum. Page generated in 0.06645 seconds
