unable to open profiling views [message #91268] |
Mon, 15 January 2007 14:04  |
Hello again,
I've got yet another problem. I'm not sure if this is related to my
previous one or not. I convinced the RAC to run by running it as root -
somehow that memory error disappeared (I didn't have to run it as root
with the old version, iirc). Now, I have a problem on the client end.
Once I connect to the RAC, I try to open the views for execution stats
and memory stats and I get an exception in Eclipse. I just updated my
TPTP a few moments ago and that seems to be the cause of this. Here's a
stack trace for the memory stats window:
ava.lang.NoClassDefFoundError:
org/eclipse/tptp/platform/common/ui/internal/CommonUIMessage s
at
org.eclipse.hyades.trace.views.adapter.internal.MemoryStatis ticViewer. <init>(MemoryStatisticViewer.java:41)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
And another for the exection stats window:
java.lang.NoSuchMethodError:
org.eclipse.hyades.trace.views.adapter.internal.MultiLevelSt atisticMethodViewer.setDefaultFilterName(Ljava/lang/String;) V
at
org.eclipse.hyades.trace.views.adapter.internal.MultiLevelSt atisticMethodViewer. <init>(MultiLevelStatisticMethodViewer.java:29)
at
org.eclipse.hyades.trace.views.adapter.internal.ExecutionSta tisticViewer2. <init>(ExecutionStatisticViewer2.java:63)
at
at
at
Sorry I have so many problems... I appreciate any help. Thanks,
Yanroy
Re: unable to open profiling views [message #92395 is a reply to message #91268] |
Fri, 09 February 2007 11:33  |
Originally posted by: dbassu.research.telcordia.com
Think I have the same problem - updated from the main TPTP update site
and now I can't open any of the views. Am not putting the stack trace
down since I see its just like the one you've posted.
Is there any way to revert back to the original condition or fix the
problem? Wish I could post the current set of active features/plugins in
my installation - is there a way to get that in some cut/paste view?
- Devasis
Yanroy wrote:
> Hello again,
> at
> Method)
> at
> at
> at
> at
> at
> Method)
> at
> at
> at
> Yanroy
FUDForum. Page generated in 0.36166 seconds
