Home » Language IDEs » Java Development Tools (JDT) » Launch eclipse refactoring wizard programatically(Launch eclipse refactoring wizard programatically)
Launch eclipse refactoring wizard programatically [message #923311] Tue, 25 September 2012 16:22 Go to next message
I want to launch one of the provided refactoring wizarard programatically (for instance rename refactoring). I want a real refactoring wizard getting launched by my function rather than an automated execution of refactoring. I found the example test case in the RenameResourceAction class of the "org.eclipse.jdt.internal.ui.refactoring.actions" package. Is it the right example to look into??? However, I am unable to find the way to initialise the IResource object which is necessary to start the refactoring.
May be someone from you can quickly guide me in the right direction.
Thanks in advance,
Obaid
Re: Launch eclipse refactoring wizard programatically [message #923461 is a reply to message #923311] Tue, 25 September 2012 19:38 Go to previous messageGo to next message
Obaid Abdul Maroof wrote on Tue, 25 September 2012 22:22
... However, I am unable to find the way to initialise the IResource object ...
What input do you have at the point where you want to open the wizard? Do you have an IJavaElement, an ISelection, a file name? Do you know the IProject / IJavaProject?
Re: Launch eclipse refactoring wizard programatically [message #923814 is a reply to message #923461] Wed, 26 September 2012 04:11 Go to previous message
Thanks for the reply. I want to open the rename refactoring wizard and for that I probably would need an ISelection or IJavaElement object, right? Lets say, I have a project and want to rename a variable 'temp' with 'temporary' in this project. and here I have to initialize the rename refactoring wizard with the above parameter(s).
Obaid
Previous Topic:how can I make this editor using RCP?
Next Topic:No jsp editor in last Juno eclipse for JEE developement
Current Time: Sat Jul 19 20:50:07 EDT 2025
Powered by FUDForum. Page generated in 0.10223 seconds
