Home » Archived » BIRT » BIRT 4.2 - Fatal Error calculating totals when there is no data
BIRT 4.2 - Fatal Error calculating totals when there is no data [message #918276] Thu, 20 September 2012 18:39 Go to next message
Hi Jason,
Could you please take a look at this simple report attached? Looks like BIRT 4.2.0 introduced an error when calculating totals and when DataSet has no data to return. The same report works fine in BIRT 3.7.0. In order to recreate just open a report in Eclipse Juno>BIRT 4.2 Designer and run it in menu>run>view report>web viewer. You should see an exception right there. All our reports with totals fail when there is no data...that's a pretty bad bug - the very basic thing like total calculation does not work in BIRT...
Aleksey
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2248)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:270)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:86)
at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1325)
at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:158)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageActionHandler.__checkDocumentExists(BirtGetPageActionHandler.java:58)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.prepareParameters(AbstractGetPageActionHandler.java:119)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:104)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:384)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
at java.lang.Thread.run(Thread.java:722)
Caused by: java.lang.ArrayIndexOutOfBoundsException: -1
at java.util.ArrayList.elementData(ArrayList.java:371)
at java.util.ArrayList.get(ArrayList.java:384)
at org.eclipse.birt.data.engine.cache.BasicCachedList.get(BasicCachedList.java:267)
at org.eclipse.birt.data.engine.executor.transform.ResultSetWrapper.getResultObjectHolder(ResultSetWrapper.java:133)
at org.eclipse.birt.data.engine.executor.transform.ResultSetWrapper.getCurrentGroupIndex(ResultSetWrapper.java:122)
at org.eclipse.birt.data.engine.executor.aggregation.ProgressiveAggregationHelper.getAggrValue(ProgressiveAggregationHelper.java:444)
at org.eclipse.birt.data.engine.executor.transform.ResultSetWrapper.getAggrValue(ResultSetWrapper.java:195)
at org.eclipse.birt.data.engine.script.JSResultSetRow.get(JSResultSetRow.java:156)
at org.mozilla.javascript.ScriptableObject.getProperty(ScriptableObject.java:1617)
at org.mozilla.javascript.ScriptRuntime.getObjectElem(ScriptRuntime.java:1390)
at org.mozilla.javascript.ScriptRuntime.getObjectElem(ScriptRuntime.java:1372)
at org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:3057)
at org.mozilla.javascript.Interpreter.interpret(Interpreter.java:2487)
at org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:164)
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:398)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3065)
at org.mozilla.javascript.InterpretedFunction.exec(InterpretedFunction.java:175)
at org.eclipse.birt.data.engine.expression.BytecodeExpression.evaluate(BytecodeExpression.java:49)
at org.eclipse.birt.data.engine.expression.ExprEvaluateUtil.evaluateCompiledExpression(ExprEvaluateUtil.java:205)
at org.eclipse.birt.data.engine.expression.ExprEvaluateUtil.evaluateCompiledExpression(ExprEvaluateUtil.java:219)
at org.eclipse.birt.data.engine.expression.ExprEvaluateUtil.evaluateExpression(ExprEvaluateUtil.java:76)
at org.eclipse.birt.data.engine.impl.BindingColumnsEvalUtil.evaluateValue(BindingColumnsEvalUtil.java:201)
at org.eclipse.birt.data.engine.impl.BindingColumnsEvalUtil.getColumnsValue(BindingColumnsEvalUtil.java:161)
at org.eclipse.birt.data.engine.impl.ResultIterator.prepareCurrentRow(ResultIterator.java:778)
at org.eclipse.birt.data.engine.impl.ResultIterator.(ResultIterator.java:168)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:212)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:83)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1939)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:249)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:262)
... 62 more
Re: BIRT 4.2 - Fatal Error calculating totals when there is no data [message #919036 is a reply to message #918276] Fri, 21 September 2012 12:14 Go to previous messageGo to next message
Aleksey
This does look like a bug. Can you log a bugzilla request for it? As a work around select your binding tab and remove the TOTAL binding. Then right click on the total data item and choose change data column. Set it to your TOTAL_AMOUNT column and the error should not happen. Another option is to delete both total bindings and delete the total data item and drag an aggregation element into the table and build your aggregate there.
Jason
Re: BIRT 4.2 - Fatal Error calculating totals when there is no data [message #919193 is a reply to message #919036] Fri, 21 September 2012 15:31 Go to previous messageGo to next message
Jason,
I logged #390063 yesterday for this issue. First, yes, I am aware of the workaround but...we use controls from the library (we have a lot of reports which is why we developed libraries) and with libraries you have to drag-and-drop data control first and then then you do the binding/expression in control expression builder. So we really can't use E (aggregation element) to begin with since it won't be derived from the library control. Second, we have converted about 100 financial reports already and as you imagine most of financial reports have some total calculations. It is not feasible for us to rework all these reports even if there was a good workaround. All these reports worked fine in BIRT 3.7.0. Now with 4.2.0, all these reports crash when there is no data returned. The issue is very serious so I am asking if it is possible say when #390063 could be fixed. I don't even mind getting a "dirty" (not 100% tested) hotfix for just this issue and then we could be waiting till BIRT 4.2.1 is available. Please, let me know what you think, really appreciate your help.
Aleksey
Re: BIRT 4.2 - Fatal Error calculating totals when there is no data [message #922168 is a reply to message #919193] Mon, 24 September 2012 16:08 Go to previous messageGo to next message
Aleksey,
I see you have responded to the bugzilla comments. Did you try the suggested work around?
Jason
Re: BIRT 4.2 - Fatal Error calculating totals when there is no data [message #923080 is a reply to message #922168] Tue, 25 September 2012 11:29 Go to previous messageGo to next message
Jason,
They provided a hotfix (org.eclipse.birt.data_4.2.0.v20120612.jar) to go under Eclispe (Juno)\plugins but I am not sure how to use it...
1) We need a hotfix not just for Eclispe (Juno)\plugins but for the ReportEngine API as we run reports using the API. So we need a new jar file to go under ReportEngine\lib. Currently, under that location there is no such jar as they provided as a hotfix. There is only org.eclipse.birt.runtime_4.2.0.v20120613-1143.jar which has some aggregation packages inside. Please, advice how to patch ReportEngine\lib.
2) Getting back to Eclispe (Juno)\plugins...There is org.eclipse.birt.data_4.2.0.v20120612.jar currently. Should I delete it and then copy the new one that you provided into the same location or should I just copy the new one and have both jars there?
3) If possible could you please hint about the timeframe as to when BIRT 4.2.1 will be available? Are we talking about 1-2 weeks, 1 month, 3 months, 6 months?
Aleksey
Re: BIRT 4.2 - Fatal Error calculating totals when there is no data [message #923136 is a reply to message #923080] Tue, 25 September 2012 12:26 Go to previous messageGo to next message
Jason,
Never mind 1) and 2) - already figured that out with Lin. The only outstanding issue is that BIRT 4.2.1 is not a "ReleaseBuild" yet. 3) Any idea about the timeframe as to when it will be available? Are we talking about 1-2 weeks, 1 month, 3 months, 6 months?
Aleksey
Re: BIRT 4.2 - Fatal Error calculating totals when there is no data [message #923350 is a reply to message #923136] Tue, 25 September 2012 17:04 Go to previous message
It becomes release build at the end of the week I believe.
Jason
Previous Topic:How to add new Report items to eclipse BIRT juno
Next Topic:folder for the list of reports
Current Time: Sat Jul 19 10:58:49 EDT 2025
Powered by FUDForum. Page generated in 0.05402 seconds
