Home » Eclipse Projects » Eclipse 4 » How to hook the "About" menu on Mac
How to hook the "About" menu on Mac [message #918792] Fri, 21 September 2012 06:51 Go to next message
On the mac, the "About", "Quit", and "Preferences..." menu items are in the application menu. Does anyone know how I can hook up my own handlers to these menu items in a E4 application with no compatibility layer?
Re: How to hook the "About" menu on Mac [message #918807 is a reply to message #918792] Fri, 21 September 2012 07:11 Go to previous messageGo to next message
Hi Thomas
In your main project, there is a *.e4xmi file (usually Application.e4xmi if you used the e4 Application Project wizard).
You can edit this file using the e4 Workbench Model Editor.
Find the Handler (Application > Handlers) which points to the Command (i.e. aboutCommand) you are looking for.
Change the Class URI an let it point to your own implementation (or use the link to open the default implementation and change it).
Greetings
Christoph
Re: How to hook the "About" menu on Mac [message #918867 is a reply to message #918807] Fri, 21 September 2012 08:26 Go to previous messageGo to next message
So ist there a bunch of "standard" handlers that get hooked up to the system menu? If so it's not working for the "quit" command. I know how register REGULAR menu items, I just don't know how to hook up the system menu on the Mac.
Re: How to hook the "About" menu on Mac [message #918874 is a reply to message #918867] Fri, 21 September 2012 08:33 Go to previous messageGo to next message
Sorry, I misunderstood your question. I don't know anything about how to change the system menu.
Re: How to hook the "About" menu on Mac [message #921469 is a reply to message #918874] Mon, 24 September 2012 02:16 Go to previous messageGo to next message
Look how the cocoa rendere addon is doing it.
Tom
Am 21.09.12 14:33, schrieb Christoph Keimel:
Re: How to hook the "About" menu on Mac [message #921816 is a reply to message #921469] Mon, 24 September 2012 09:02 Go to previous message
The Cocoa addon (org.eclipse.e4.ui.workbench.renderers.swt.cocoa) redirects About, Preferences, and Quit to the corresponding Eclipse 3.x command ids (respectively org.eclipse.ui.help.aboutAction, org.eclipse.ui.window.preferences, and org.eclipse.ui.file.exit). Declare a command for those ids in your .e4xmi and provide a handler.
Brian.
Previous Topic:Scrollbar color
Next Topic:TreeViewer context menu does not show up
Current Time: Sun Jul 20 03:08:56 EDT 2025
Powered by FUDForum. Page generated in 0.03920 seconds
