Workspace crash!! [message #918328] |
Thu, 20 September 2012 19:50 |
Please guys give some ideas about how fix this problem
!SESSION 2012-09-20 18:39:32.599 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.7.0_05
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.objectteams.otequinox.hook 1 0 2012-09-20 18:39:33.039
!MESSAGE Created equinox adaptor hook: org.eclipse.objectteams.otequinox.internal.hook.TransformerHook.
(To disable this and subsequent INFO messages from OT/Equinox set otequinox.debug to WARN or ERROR).
!ENTRY org.eclipse.objectteams.otequinox.hook 1 0 2012-09-20 18:39:45.569
!MESSAGE OT/Equinox: connected the transformer service
!ENTRY org.eclipse.objectteams.otequinox.hook 1 0 2012-09-20 18:40:02.959
!MESSAGE hot-patched a bug in class org.apache.bcel.generic.InstructionHandle
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=344350
!ENTRY org.eclipse.objectteams.otequinox.hook 1 0 2012-09-20 18:40:02.969
!MESSAGE hot-patched a bug in class org.apache.bcel.generic.BranchHandle
!ENTRY org.eclipse.core.net 1 0 2012-09-20 18:40:12.579
!MESSAGE System property http.proxyHost is not set but should be cproxy.
!ENTRY org.eclipse.core.net 1 0 2012-09-20 18:40:12.589
!MESSAGE System property http.proxyPort is not set but should be 8080.
!MESSAGE System property https.proxyHost is not set but should be cproxy.
!MESSAGE System property https.proxyPort is not set but should be 8080.
!ENTRY org.eclipse.osgi 4 0 2012-09-20 18:40:13.679
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4361)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.swt.widgets.Display.release(Display.java:3814)
at org.eclipse.swt.graphics.Device.dispose(Device.java:295)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:140)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1228)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1221)
at org.eclipse.cdt.codan.internal.ui.cxx.Startup$1.run(Startup.java:39)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 17 more
!ENTRY org.eclipse.mylyn.tasks.ui 4 0 2012-09-20 18:40:14.069
!MESSAGE Could not load presentation extension
!STACK 0
at org.eclipse.ui.plugin.AbstractUIPlugin.imageDescriptorFromPlugin(AbstractUIPlugin.java:670)
at org.eclipse.mylyn.internal.tasks.ui.util.TasksUiExtensionReader.readPresentation(TasksUiExtensionReader.java:465)
at org.eclipse.mylyn.internal.tasks.ui.util.TasksUiExtensionReader.initStartupExtensions(TasksUiExtensionReader.java:266)
at org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.start(TasksUiPlugin.java:583)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:273)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:52)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:269)
at org.eclipse.ui.internal.EarlyStartupRunnable.getExecutableExtension(EarlyStartupRunnable.java:117)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
at org.eclipse.ui.internal.Workbench$52.run(Workbench.java:2357)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!STACK 0
!ENTRY org.eclipse.mylyn.tasks.core 4 0 2012-09-20 18:40:14.119
!MESSAGE Task activity monitor failed to load for extension contributed by org.eclipse.mylyn.context.tasks.ui
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.mylyn.context.tasks.ui" was unable to instantiate class "org.eclipse.mylyn.internal.context.tasks.ui.TaskActivityMonitor".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:186)
at org.eclipse.mylyn.internal.tasks.ui.util.TasksUiExtensionReader.loadTaskActivityMonitor(TasksUiExtensionReader.java:650)
at org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.start(TasksUiPlugin.java:593)
at org.eclipse.mylyn.internal.context.core.ContextCorePlugin.getContextManager(ContextCorePlugin.java:205)
at org.eclipse.mylyn.internal.context.tasks.ui.TaskActivityMonitor.<init>(TaskActivityMonitor.java:96)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
... 37 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-09-20 18:40:14.119
!MESSAGE Plug-in "org.eclipse.mylyn.context.tasks.ui" was unable to instantiate class "org.eclipse.mylyn.internal.context.tasks.ui.TaskActivityMonitor".
!STACK 0
!ENTRY org.eclipse.mylyn.tasks.ui 4 0 2012-09-20 18:40:14.129
!MESSAGE Task list initialization failed
!STACK 0
at org.eclipse.mylyn.internal.context.tasks.ui.TaskContextStore.setDirectory(TaskContextStore.java:232)
at org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.initializeDataSources(TasksUiPlugin.java:874)
at org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.start(TasksUiPlugin.java:625)
!ENTRY org.eclipse.mylyn.tasks.ui 4 0 2012-09-20 18:40:14.139
!MESSAGE Task list stop terminated abnormally
!STACK 0
at org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.stop(TasksUiPlugin.java:787)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:771)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:764)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:510)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:566)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1207)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:592)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:284)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:693)
at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:600)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:399)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:199)
!ENTRY org.eclipse.mylyn.monitor.ui 4 0 2012-09-20 18:40:14.149
!MESSAGE Monitor UI stop failed
!STACK 0
at org.eclipse.mylyn.internal.monitor.ui.ActivityContextManager.stop(ActivityContextManager.java:152)
at org.eclipse.mylyn.internal.monitor.ui.MonitorUiPlugin.stop(MonitorUiPlugin.java:157)
!ENTRY org.eclipse.dltk.launching 2 4 2012-09-20 18:40:14.369
!MESSAGE Failed to resolve library locations for ruby.exe with C:\Temp\galiciai\dltk41581.tmp\scripts\path.rb
!STACK 0
java.lang.Exception: Output:
at org.eclipse.dltk.internal.launching.AbstractInterpreterInstallType$2.run(AbstractInterpreterInstallType.java:719)
at org.eclipse.dltk.internal.launching.AbstractInterpreterInstallType.runLibraryLookup(AbstractInterpreterInstallType.java:428)
at org.eclipse.dltk.internal.launching.AbstractInterpreterInstallType.getDefaultLibraryLocations(AbstractInterpreterInstallType.java:776)
at org.eclipse.dltk.launching.ScriptRuntime.getLibraryLocations(ScriptRuntime.java:978)
at org.eclipse.dltk.launching.ScriptRuntime.getLibraryLocations(ScriptRuntime.java:966)
at org.eclipse.dltk.internal.launching.InterpreterContainer.computeBuildpathEntries(InterpreterContainer.java:135)
at org.eclipse.dltk.internal.launching.InterpreterContainer.getBuildpathEntries(InterpreterContainer.java:118)
at org.eclipse.dltk.internal.launching.InterpreterContainer.computeBuildpathEntries(InterpreterContainer.java:221)
at org.eclipse.dltk.internal.launching.InterpreterContainer.getBuildpathEntries(InterpreterContainer.java:215)
at org.eclipse.dltk.internal.core.ModelManager.containerPutIfInitializingWithSameEntries(ModelManager.java:2065)
at org.eclipse.dltk.core.DLTKCore.setBuildpathContainer(DLTKCore.java:1982)
at org.eclipse.dltk.internal.launching.InterpreterContainerInitializer.initialize(InterpreterContainerInitializer.java:62)
at org.eclipse.dltk.internal.core.ModelManager.initializeContainer(ModelManager.java:1837)
at org.eclipse.dltk.internal.core.ModelManager.getBuildpathContainer(ModelManager.java:1667)
at org.eclipse.dltk.core.DLTKCore.getBuildpathContainer(DLTKCore.java:1769)
at org.eclipse.dltk.internal.core.ScriptProject.getResolvedBuildpath(ScriptProject.java:459)
at org.eclipse.dltk.internal.core.ScriptProject.getResolvedBuildpath(ScriptProject.java:330)
at org.eclipse.dltk.internal.core.ScriptProject.getAllProjectFragments(ScriptProject.java:3192)
at org.eclipse.dltk.internal.core.ScriptProject.getAllProjectFragments(ScriptProject.java:3185)
at org.eclipse.dltk.core.search.indexing.core.ProjectRequest.run(ProjectRequest.java:67)
at org.eclipse.dltk.core.search.indexing.AbstractJob.execute(AbstractJob.java:76)
at org.eclipse.dltk.internal.core.search.processing.JobManager.run(JobManager.java:467)
!ENTRY org.eclipse.core.resources 4 0 2012-09-20 18:41:14.219
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.stop() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:791)
at org.eclipse.ui.internal.progress.BlockedJobsDialog.createBlockedDialog(BlockedJobsDialog.java:218)
at org.eclipse.ui.internal.dialogs.WorkbenchDialogBlockedHandler.showBlocked(WorkbenchDialogBlockedHandler.java:73)
at org.eclipse.ui.internal.dialogs.WorkbenchDialogBlockedHandler.showBlocked(WorkbenchDialogBlockedHandler.java:87)
at org.eclipse.ui.internal.dialogs.EventLoopProgressMonitor.setBlocked(EventLoopProgressMonitor.java:144)
at org.eclipse.core.internal.jobs.JobManager.reportBlocked(JobManager.java:1032)
at org.eclipse.core.internal.jobs.ThreadJob.waitStart(ThreadJob.java:436)
at org.eclipse.core.internal.jobs.ThreadJob.waitForRun(ThreadJob.java:210)
at org.eclipse.core.internal.jobs.ThreadJob.joinRun(ThreadJob.java:197)
at org.eclipse.core.internal.jobs.ImplicitJobs.begin(ImplicitJobs.java:92)
at org.eclipse.core.internal.jobs.JobManager.beginRule(JobManager.java:286)
at org.eclipse.core.internal.resources.WorkManager.checkIn(WorkManager.java:118)
at org.eclipse.core.internal.resources.Workspace.prepareOperation(Workspace.java:2282)
at org.eclipse.core.internal.resources.Workspace.close(Workspace.java:605)
at org.eclipse.core.resources.ResourcesPlugin.stop(ResourcesPlugin.java:415)
... 18 more
Root exception:
!ENTRY org.eclipse.core.resources 4 1 2012-09-20 18:41:14.219
!MESSAGE Internal Error
!STACK 0
at org.eclipse.core.internal.resources.Resource.getStore(Resource.java:1288)
at org.eclipse.core.internal.localstore.UnifiedTreeNode.getStore(UnifiedTreeNode.java:85)
at org.eclipse.core.internal.localstore.UnifiedTree.getLocalList(UnifiedTree.java:342)
at org.eclipse.core.internal.localstore.UnifiedTree.addChildren(UnifiedTree.java:139)
at org.eclipse.core.internal.localstore.UnifiedTree.addNodeChildrenToQueue(UnifiedTree.java:245)
at org.eclipse.core.internal.localstore.UnifiedTree.accept(UnifiedTree.java:111)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.refreshResource(FileSystemResourceManager.java:920)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.refresh(FileSystemResourceManager.java:904)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.refreshRoot(FileSystemResourceManager.java:951)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.refresh(FileSystemResourceManager.java:897)
at org.eclipse.core.internal.resources.Resource.refreshLocal(Resource.java:1700)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor$4.runInWorkspace(IDEWorkbenchAdvisor.java:404)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
!ENTRY org.eclipse.core.resources 4 566 2012-09-20 18:41:14.219
!MESSAGE Workspace was not properly initialized or has already shutdown.
!ENTRY org.eclipse.core.jobs 4 1 2012-09-20 18:41:14.219
!MESSAGE Worker thread ended job: Refreshing workspace(18), but still holds rule: ThreadJob(Refreshing workspace(18),[R/,])
!ENTRY org.eclipse.core.jobs 2 2 2012-09-20 18:41:15.849
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.dltk.internal.core.ModelManager$4
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.progress.ProgressManager$4
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.mylyn.internal.builds.ui.BuildsStartup$1
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.dltk.internal.ui.InitializeJob
FUDForum. Page generated in 0.08514 seconds
