Home » Eclipse Projects » Rich Client Platform (RCP) » Text-Editor - update from Indigo to Juno
Text-Editor - update from Indigo to Juno [message #918225] Thu, 20 September 2012 17:32 Go to next message
We have had an RCP-Application for quite some time and everything was working fine. Lately we updated to Eclipse 4 (Juno) and now we are running into problems. Starting the application and most parts of it are working just as excpected. However it is not possible to create or open simple text files (or *.properties files).
It seems that there is an issue with the e4-compatibility layer. Additional libraries are xtext/xpand and some logging libraries. Maybe I'm missing a plug-in or something?
(all e4-plugins are in the launch config as well as org.eclipse.equinox.ds, org.eclipse.equinox.events and org.eclipse.equinox.util)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-09-20 23:21:44.345
!MESSAGE Unable to create class 'org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor' from bundle '379'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException: can't find IDfind.ext
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:837)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:318)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:889)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:623)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:725)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:696)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:690)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:675)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1042)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:67)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4291)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:57)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:418)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:385)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:578)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:314)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:962)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3071)
	at org.eclipse.ui.internal.WorkbenchPage.access$21(WorkbenchPage.java:2996)
	at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2978)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2974)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2933)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2924)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:655)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:614)
	at org.eclipse.ui.wizards.newresource.BasicNewFileResourceWizard.performFinish(BasicNewFileResourceWizard.java:111)
	at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3554)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3179)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.ui.internal.navigator.wizards.WizardShortcutAction.run(WizardShortcutAction.java:98)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
	at org.sofarproject.ide.Application.start(Application.java:50)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:616)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.IllegalArgumentException: can't find IDfind.ext
	at org.eclipse.jface.action.ContributionManager.insertAfter(ContributionManager.java:334)
	at org.eclipse.jface.action.SubContributionManager.insertAfter(SubContributionManager.java:159)
	at org.eclipse.ui.internal.EditorMenuManager.prependToGroup(EditorMenuManager.java:122)
	at org.eclipse.jface.action.SubContributionManager.prependToGroup(SubContributionManager.java:261)
	at org.eclipse.ui.texteditor.BasicTextEditorActionContributor.contributeToMenu(BasicTextEditorActionContributor.java:256)
	at org.eclipse.ui.editors.text.TextEditorActionContributor.contributeToMenu(TextEditorActionContributor.java:129)
	at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:167)
	at org.eclipse.ui.editors.text.TextEditorActionContributor.init(TextEditorActionContributor.java:159)
	at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:146)
	at org.eclipse.ui.internal.EditorReference.createEditorActionBars(EditorReference.java:405)
	at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:320)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:288)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	... 93 more
!ENTRY org.eclipse.ui 4 0 2012-09-20 23:21:44.418
!MESSAGE Unhandled event loop exception
!STACK 0
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3087)
Re: Text-Editor - update from Indigo to Juno [message #992026 is a reply to message #918225] Thu, 20 December 2012 12:54 Go to previous messageGo to next message
Hi Mark,
I have the same issue. Furthermore, it's at my setup not possible to show other editors (standard and self defined) in the 3.x editor area. But curiously, if I launch my application with the app definition "org.eclipse.ui.ide.workbench" it works. Don't ask me why? It seems to be one of the mysterious things of the Eclipse IDE. Both my own and the "org.eclipse.ui.ide.workbench" are based on the same feature, hence I would assume that both should show the editors correctly. They don't.
I would be also very thankful, if someone has a solution for the problem.
Re: Text-Editor - update from Indigo to Juno [message #1014895 is a reply to message #992026] Tue, 26 February 2013 11:59 Go to previous message
Just ran into the same thing during our port has anyone figured this out
yet?
"Philip Wenig" <forums-noreply@xxxxxxxx> wrote in message
news:kb063b$8ck$1@xxxxxxxxe.org...
> Hi Mark,
Previous Topic:Possible to set title of view shortcuts in 3.7 perspective?
Next Topic:Solution to our Juno based RCP application with Text Editors not opening correctly
Current Time: Sun Jul 20 19:41:35 EDT 2025
Powered by FUDForum. Page generated in 0.03801 seconds
