Load Timeout for Plugins [message #902062] |
Wed, 15 August 2012 13:18  |
Hello All,
I wonder if anyone can shed light on my plugin installing issue,
I am getting "Load timeout for plugin: http:<address-of-plugin>.html" on any plugin I try to install, this happens on both orionhub and on a local Orion server, and happens whichever way I try to install plugins (i.e via URL directly or the settings > plugins panel)
I have even gotten this message from the simple plugin example (reverses selected text) given in the Orion documentation.
I have tried installing from a remote site and an Orion page-as-site but to no avail, the plugin.js file is referenced correctly in all cases and I have also tried with the contents of plugin.js pasted into a <script> block, also to no avail.
What could I be missing or doing incorrectly? (entirely possible I'm just being dumb)
Thank You
Edit: Clarity
[Updated on: Wed, 15 August 2012 15:37] by Moderator
Re: Load Timeout for Plugins [message #916234 is a reply to message #902062] |
Tue, 18 September 2012 15:27  |
You shouldn't have to hack the built in Orion plugins to get this working. I don't know what is causing it, but you could look at some of the examples of "external" plugins in this catalog:
http://mamacdon.github.com/
All of these plugins will install into a remote Orion, either localhost or hosted elsewhere. Note you should have a copy of the plugin.js in your plugin and not rely on some external script location.
John
FUDForum. Page generated in 0.03237 seconds
