Home » Language IDEs » C / C++ IDE (CDT) » java.lang.NullPointerException in CDT(Java Null Pointer Exception in a C++ Project)
java.lang.NullPointerException in CDT [message #915320] Sun, 16 September 2012 23:39 Go to next message
when I try to build my CDT project on my system using Eclipse Juno I get a java.lang.NullPointer exception I don't know how to fix. The project is in C++ and I am in the correct perspecvtive.
-Ted
Re: java.lang.NullPointerException in CDT [message #915539 is a reply to message #915320] Mon, 17 September 2012 09:37 Go to previous messageGo to next message
If you are running on Ubuntu and use Open JDK, then you might be hit by a bug in the latest Ubuntu update. It breaks time zone information.
The workaround is to re-install the tzdata-java package.
Re: java.lang.NullPointerException in CDT [message #915760 is a reply to message #915539] Mon, 17 September 2012 19:02 Go to previous messageGo to next message
Yeah I saw that bug, no I am running this instance of eclipse on Windows 7.
Development environment is up to date as well (I forgot to mention).
Re: java.lang.NullPointerException in CDT [message #916221 is a reply to message #915760] Tue, 18 September 2012 14:46 Go to previous message
Hello Ted,
how could we help in this case? There are 2718281 possibility's (more or less) to get an NullPointerExeption...
What did you try in the meantime?
For example, make a new Workspace, create the Hello-C++ example and look, what happens?
Good questions will lead to better answers...
regards,
klaus
Previous Topic:C/C++ Linker Tab missing [SOLVED]
Next Topic:Problem installing Eclipse+opencv+windows xp
Current Time: Sun Jul 20 18:12:34 EDT 2025
Powered by FUDForum. Page generated in 0.04782 seconds
