Home » Archived » BIRT » Scripted Dataset
Scripted Dataset [message #915443] Mon, 17 September 2012 05:31 Go to next message
Dear Jason,
I am creating a dynamic report that gets the column names as a parameter.
However, the parameter is too long and is thus truncated.
As a result, I want to get the parameter by running a query from a runtime dataset.
I want to be able to:
1. create a dataset at beforeFactory event,
2. Pass in the sql string
3. fill the dataset (with only one record)
4. and access the first row in the dataset and extract the filed value
I can thus continue with the creation of the dynamic report with the full list of columns without being truncated
Is this possible
Any kind help would be the most welcomed...
Thanks a lot
Karvesh
Re: Scripted Dataset [message #915656 is a reply to message #915443] Mon, 17 September 2012 13:36 Go to previous message
You may want to look over this thread:
http://www.eclipse.org/forums/index.php/m/892804/
Jason
Previous Topic:How to read get data of a generated .rptDocument from Before Factory using design engine api .
Next Topic:radar chart, highlighting only one radarline
Current Time: Sun Jul 20 09:55:07 EDT 2025
Powered by FUDForum. Page generated in 0.05318 seconds
