VE N20050516 problems with M7 [message #91411] |
Tue, 17 May 2005 12:55  |
I'm unable to open a visual class with the new N20050516 for M7.
When I try to open the class, a message box appears with the following
message:
"Error trying to set new file into editor.
Reason: org.eclipse.ve.internal.java.core.BeanProxyAdapter".
I'm working over a clean Eclipse 3.1 M7 installation and a M6 workspace
(W2K).
Thanks in advance for your help,
Francesc Rosés
Re: VE N20050516 problems with M7 [message #91673 is a reply to message #91659] |
Wed, 18 May 2005 14:03  |
I checkout ve manual with (linux)
cvs co ve-all
I import existing projects (all plugins) in eclipse.
I try first export existing feature and it doesn't work
I make simple feature project and add all ve-plugins
export this feature and get logs.zip with error in 3 plugins
I the export this 3 plugins separately (one by one) and it compile fine
(mystery)
all is fine in runtime workbench (always), but I have error when deploy
plugins (sometimes) because exits error in build.properties
Rich Kulp wrote:
> How are you building? It works fine if you check out through Eclipse and
> let the standard incremental editor compile them.
> If you are trying to build this outside of Eclipse:
> For jem.util: Create a dummy plugin called org.eclipse.perfmsr.core and
> put the perfmsr.jar found in the org.eclipse.jem.util checked CVS files.
> This is a stripped down only for compile against version of the jar. It
> will not run and it should not be in the runtime. It should only be in
> the build path.
> I don't understand the other other problems. You weren't specific.
Re: VE N20050516 problems with M7 [message #607789 is a reply to message #91411] |
Tue, 17 May 2005 17:17  |
There are problems with the Nightly build. It was a first pass and
mostly Swing/AWT works but SWT has problems.
Did you run eclipse.exe -clean first after you unzipped the driver? You
need to do that to pick up the new code.
Francesc Rosés wrote:
> Hello,
> message:
> (W2K).
> Francesc Rosés
Rich Kulp
Re: VE N20050516 problems with M7 [message #607791 is a reply to message #91476] |
Tue, 17 May 2005 20:08  |
Rich,
I find similar problem when build from cvs
it work in runtime workbench, but 'create visual class' (swing application,
frame etc) doesn't work whe I build vep
reason : plugin org.eclipse.ve.jfc = build properties doesn't include
directory templates and i get 'null pointer error'
There are another files/directories non included in another plugins
regards
Haris Peco
>> Hello,
>> message:
>> (W2K).
>> Francesc Rosés
Re: VE N20050516 problems with M7 [message #607794 is a reply to message #91533] |
Tue, 17 May 2005 18:42  |
Oh, you said you were using an M6 workspace. You will also need to run
Project->Clean->Clean All Projects. There are some cached files laying
around from M6 that have changed and need to be recreated. See if that
helps.
> Hello Rich,
> Yes I run Eclipse.exe with -clean.
> Francesc
Rich Kulp
Re: VE N20050516 problems with M7 [message #607795 is a reply to message #91505] |
Tue, 17 May 2005 19:00  |
Yeah we just found the templates problem this afternoon. We just created
a new nightly build that fixes that problem, N20050517.
snpe wrote:
> Rich,
Rich Kulp
Re: VE N20050516 problems with M7 [message #607796 is a reply to message #91561] |
Tue, 17 May 2005 21:37  |
I see.Sorry.
I build from cvs and it work fine, but I have to build plugins
org.eclipse.jem.util - have problem with perfmsr.jar
org.eclipse.ve.jfc - return error when build with any another plugin
org.eclipse.ve.swt - like jfc
out of another plugin - I can set features and include all plugins
regards
> snpe wrote:
>> Rich,
>> application, frame etc) doesn't work whe I build vep
Re: VE N20050516 problems with M7 [message #607802 is a reply to message #91575] |
Wed, 18 May 2005 11:42  |
the build path.
Rich Kulp
Re: VE N20050516 problems with M7 [message #607803 is a reply to message #91659] |
cvs co ve-all
(mystery)
> the build path.
FUDForum. Page generated in 1.23305 seconds
