Home » Eclipse Projects » Rich Client Platform (RCP) » org.eclipse.e4.core.di.InjectionException: org.eclipse.core.runtime.AssertionFailedException:(org.eclipse.e4.core.di.InjectionException: org.eclipse.core.runtime.AssertionFailedException:)
org.eclipse.e4.core.di.InjectionException: org.eclipse.core.runtime.AssertionFailedException: [message #915364] Mon, 17 September 2012 02:28
!SESSION 2012-09-17 10:18:28.201 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0
Framework arguments: -product ESC_Configurator_Tool.product
Command-line arguments: -product ESC_Configurator_Tool.product -data C:\escconfiguratortool/../runtime-ESCConfiguratorTool.product -dev file:C:/escconfiguratortool/.metadata/.plugins/org.eclipse.pde.core/ESC Configurator Tool.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2012-09-17 10:18:30.680
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
org.eclipse.e4.core.di.InjectionException: org.eclipse.core.runtime.AssertionFailedException: null argument:Action must not have null id
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:81)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:72)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1249)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1221)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:924)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:133)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:684)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1664)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2145)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4525)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:231)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1217)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:710)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:639)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:725)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:696)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:690)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:675)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:957)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at esc_configurator_tool.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:Action must not have null id
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.ui.application.ActionBarAdvisor.register(ActionBarAdvisor.java:191)
at esc_configurator_tool.ApplicationActionBarAdvisor.makeActions(ApplicationActionBarAdvisor.java:77)
at org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(ActionBarAdvisor.java:148)
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:2050)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:523)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 53 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-09-17 10:18:30.683
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@442e5d (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {MSI's ESC Configuration Generator in RCP}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@106fd16, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: -2147483648, y: -2147483648, width: 1024, height: 768)
!STACK 0
... 53 more
Previous Topic:Quick Start RCP
Next Topic:Cut,Copy commands enabledWhen
Current Time: Sun Jul 20 12:04:30 EDT 2025
Powered by FUDForum. Page generated in 0.03385 seconds
