Home » Eclipse Projects » Eclipse Platform » Installing Manually Eclipse
Installing Manually Eclipse [message #912613] Thu, 13 September 2012 17:20 Go to next message
I want to keep my Eclipse up to-date.
It's Ok via the help menu-> Check for updates, but what if I wanted
Maintenance updates?
What's the best practice to updates Eclipse manually (replacing folders : plugins, features, without loosing all the downloaded plugins)
I tried this: downloaded the Maintenance build and replaced the eclipse app
and the feature and plugins folder, but lost every plug-ins I installed and the config was a mess up.
So I was forced to redownload eclipse and perform another installment of many plug-ins.
Do anybody have a solution for that?
tx
Re: Installing Manually Eclipse [message #912720 is a reply to message #912613] Thu, 13 September 2012 23:41 Go to previous messageGo to next message
Don't change things manually. You can add and remove things
(bundles/features) from the dropins folder, but don't mess with the
plugins or features folder and don't just unzip a new Eclipse over top
of an old one.
> eclipse app
> of many plug-ins.
> tx
Re: Installing Manually Eclipse [message #913149 is a reply to message #912720] Fri, 14 September 2012 17:32 Go to previous messageGo to next message
Thank you very much, but how do you use the "dropins" Folder ?
If I downloads a new Maintenance, Stable or Nightly Build, do I unzip it all into the "dropins" Folders?
tx
Re: Installing Manually Eclipse [message #913278 is a reply to message #913149] Sat, 15 September 2012 02:10 Go to previous messageGo to next message
Ask Google about "eclipse dropins folder"
> tx
Re: Installing Manually Eclipse [message #913313 is a reply to message #913149] Sat, 15 September 2012 04:13 Go to previous messageGo to next message
"Average" Eclipse app typically contains some features (groups of
plug-ins) and plug-ins. And may accept _individual_ plug-ins through
placing them into dropins/ folder.
Dropins/ is watched by Equinox p2 (Equinox has own forum here at Eclipse
also) and a basic overview of purpose and layout is for example at
http://wiki.eclipse.org/Equinox/p2/Getting_Started#Dropins
Libor
> tx
Re: Installing Manually Eclipse [message #915648 is a reply to message #913313] Mon, 17 September 2012 13:20 Go to previous message
I wouldn't use dropins for a whole Eclipse update. I found that since
Eclipse needs to scan the dropins folders on every start up it can
severely impact the startup time depending on how much you put in there.
The basic reason I use dropins is for test purposes of new code and then
when completed I put the new code into an update site and remove it from
the dropins, and finally let it then be officially installed thru the
update manager.
Rich
Previous Topic:can't deactivate context on workbench window
Next Topic:How can I test with selection at PropertyTest?
Current Time: Sat Jul 19 17:54:54 EDT 2025
Powered by FUDForum. Page generated in 0.32278 seconds
