Home » Eclipse Projects » Rich Client Platform (RCP) » ApplyPreferences causes Default Preferences to disappear
ApplyPreferences causes Default Preferences to disappear [message #912934] Fri, 14 September 2012 08:34 Go to next message
I implemented a feature for multiple user preferences. The export of the UserPreferences is working ok. with
 IPreferencesService service = Platform.getPreferencesService();
 File exportFile = File.createTempFile(USER_PREFERENCE_FILE_PREFIX,
           USER_PREFERENCE_FILE_SUFFIX, toFolder);
 os = new FileOutputStream(exportFile);
 service.exportPreferences(service.getRootNode(), os, null);
I also initialize my DefaultValues with the PreferenceInitializer framework.
But when I try to load the stored Preferences, all my default values are gone.
I load them with following code:
        IExportedPreferences prefs;
        try {
            prefs = service.readPreferences(new FileInputStream(new File(
                    selectedFile)));
            service.applyPreferences(prefs, getTransfers());
        } catch (FileNotFoundException e) {
            ExceptionDialog.show(e, shell);
        } catch (CoreException e) {
        return null;
    private static IPreferenceFilter[] getTransfers() {
        IPreferenceFilter[] transfers = new IPreferenceFilter[1];
        // For export all create a preference filter that can export
        // all nodes of the Instance and Configuration scopes
        transfers[0] = new IPreferenceFilter() {
            public String[] getScopes() {
                return new String[] { InstanceScope.SCOPE,
                        ConfigurationScope.SCOPE };
            @SuppressWarnings("rawtypes")
            public Map getMapping(String scope) {
                return null;
        return transfers;
I`m using Eclipse 3.6 as RCP
Is there a bug or am I doing something wrong here?
Re: ApplyPreferences causes Default Preferences to disappear [message #912975 is a reply to message #912934] Fri, 14 September 2012 10:11 Go to previous messageGo to next message
Hi ... I`m sorry .. I have no Idea what I have done wrong but the problem I described above does not appear anymore.
But I run into another one.
The Problem is that the Preference Export only exports Preferences that differ from the default value.
So it is not possible to reset changed Preferences to the default by loading a stored PreferenceFile.
Does anyone know a way to solve this.
e.g.
- export every single preference
- reset the entire workbench to the default values
Re: ApplyPreferences causes Default Preferences to disappear [message #915958 is a reply to message #912975] Tue, 18 September 2012 05:46 Go to previous messageGo to next message
See https://bugs.eclipse.org/246754
Dani
> e.g. - export every single preference - reset the entire workbench to
> the default values
Re: ApplyPreferences causes Default Preferences to disappear [message #917922 is a reply to message #915958] Thu, 20 September 2012 11:11 Go to previous message
Thanks for the link.
In the meantime I implemented a workaround:
1. I exported all default values into a file
2. I removed all preferences with empty values
3. I changed the scope into /instance/
4. I imported these preferencefile
After that all preferences are set back to default.
Previous Topic:disposing the Perspective
Next Topic:InjectionException: java.lang.NoClassDefFoundError: XmlSchemaCollection
Current Time: Sun Jul 20 12:19:27 EDT 2025
Powered by FUDForum. Page generated in 0.03687 seconds
