Home » Archived » BIRT » problem with output parameters
problem with output parameters [message #904509] Tue, 28 August 2012 10:59 Go to next message
I have problem when i want to display stored procedures output parameters on birt report. When I create data set in it's properties I'm able to see these parameters in preview output parameters tab, so i successfully fetch them from database. Also when I try to display only one output parameter on report, I'm able to see result when I press preview tab. But I'm not able to see any other output parameter that I add after this one.
I'm adding this parameters using data item form palette view.
My database is sql server 2008
Re: problem with output parameters [message #904636 is a reply to message #904509] Tue, 28 August 2012 17:21 Go to previous messageGo to next message
Are you using outputParams["parametername"] In the expression?
Jason
> add after this one.
Re: problem with output parameters [message #904875 is a reply to message #904636] Wed, 29 August 2012 05:52 Go to previous messageGo to next message
Yes, and as I said it is not problem when i want to show only one output parameter. Problem is when I put more then one data items whose expressions are outputParams["parametername"]. In that situation i'm able to see only that first one output parameter. Others are not visible
Re: problem with output parameters [message #905048 is a reply to message #904875] Wed, 29 August 2012 11:32 Go to previous messageGo to next message
Can you post a report that has this issue?
Jason
Re: problem with output parameters [message #905346 is a reply to message #905048] Thu, 30 August 2012 04:00 Go to previous messageGo to next message
Here it is.
It shows all data correctly except outputParams["@P_PTT_MJESTO"] which is in the last data item. I tried to put other output parameters in this data item but nothing changes.
Re: problem with output parameters [message #905348 is a reply to message #905048] Thu, 30 August 2012 04:01 Go to previous messageGo to next message
No Message Body
Re: problem with output parameters [message #905594 is a reply to message #905346] Thu, 30 August 2012 13:45 Go to previous messageGo to next message
If the data item that shows outputParams["@P_PTT_MJESTO"] is in the
table footer instead of outside the table does it work ?
Jason
On 8/30/2012 4:00 AM, milos Srbija wrote:
> Here it is.
Re: problem with output parameters [message #905949 is a reply to message #905594] Fri, 31 August 2012 07:03 Go to previous messageGo to next message
No it doesn't work. I tried to put it in table, grid but it stil doesn't work. Unless it's first element in the report. Data item that shows report.outputParams["@P_VRATI_NASLOV"]+"\n"+outputParams["@P_VRATI_RACUN"] works fine, but if I exchange positions of these to data items, then data item that shows outputParams["@P_PTT_MJESTO"] works, but other one doesn't. Thank you for helping me Jason.
Re: problem with output parameters [message #906118 is a reply to message #905949] Fri, 31 August 2012 12:45 Go to previous messageGo to next message
This sounds like a bug, but as a test can you add an onFetch method to
the data set and put in a script like:
var ap = outputParams["ap"];
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/test/outputparmsevents.txt",
true ) );
out.println( "AP " + ap);
out.close();
Change to your output parameters and add all of them.
Jason
Re: problem with output parameters [message #907199 is a reply to message #906118] Mon, 03 September 2012 10:03 Go to previous messageGo to next message
Jason, I did what you ask.
outputparamsevents.txt file was successfully created and all my output parameters were written successfully. I started report only once but output parameters were written three times, I believe once for every item in report: data, table and then again data item.
This is what I got in web browser when I started report.
03.09.2012. 15.52
The following items have errors:
Data (id = 295):
- Cannot fetch the next data row.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot move down to next row in the result set.
SQL error #1:The result set is closed.
com.microsoft.sqlserver.jdbc.SQLServerException: The result set is closed. (Element ID:295)
odaconsumer.CannotFetchNextRow ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Cannot fetch the next data row.
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1237)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1216)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.DataItemExecutor.execute(DataItemExecutor.java:75)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:937)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:877)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:594)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1675)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot fetch the next data row.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
at org.eclipse.birt.data.engine.odaconsumer.ResultSet.fetch(ResultSet.java:143)
at org.eclipse.birt.data.engine.executor.dscache.DataSetToCache.fetchFromDataSet(DataSetToCache.java:240)
at org.eclipse.birt.data.engine.executor.dscache.DataSetToCache.fetch(DataSetToCache.java:171)
at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch(OdiAdapter.java:218)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.doNext(RowResultSet.java:113)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.next(RowResultSet.java:91)
at org.eclipse.birt.data.engine.executor.cache.ExpandableRowResultSet.next(ExpandableRowResultSet.java:63)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.populateData(SmartCacheHelper.java:316)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.initInstance(SmartCacheHelper.java:285)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.getResultSetCache(SmartCacheHelper.java:246)
at org.eclipse.birt.data.engine.executor.cache.SmartCache.<init>(SmartCache.java:73)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.populateOdiResultSet(PassUtil.java:132)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.pass(PassUtil.java:62)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.doSinglePass(PassManager.java:170)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.prepareDataSetResultSet(PassManager.java:94)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.populateDataSetResultSet(PassManager.java:80)
at org.eclipse.birt.data.engine.executor.transform.ResultSetPopulator.cacheDataSet(ResultSetPopulator.java:203)
at org.eclipse.birt.data.engine.executor.transform.CachedResultSet.<init>(CachedResultSet.java:142)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:1034)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:428)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1142)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:177)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init>(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1939)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
... 55 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot move down to next row in the result set.
at org.eclipse.birt.report.data.oda.jdbc.ResultSet.next(ResultSet.java:197)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaResultSet.next(OdaResultSet.java:180)
at org.eclipse.birt.data.engine.odaconsumer.ResultSet.fetch(ResultSet.java:138)
... 82 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The result set is closed.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:190)
at com.microsoft.sqlserver.jdbc.SQLServerResultSet.checkClosed(SQLServerResultSet.java:372)
at com.microsoft.sqlserver.jdbc.SQLServerResultSet.next(SQLServerResultSet.java:994)
at org.eclipse.birt.report.data.oda.jdbc.ResultSet.next(ResultSet.java:188)
... 84 more
Table (id = 236):
com.microsoft.sqlserver.jdbc.SQLServerException: The result set is closed. (Element ID:236)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
... 55 more
... 82 more
... 84 more
Data (id = 296):
com.microsoft.sqlserver.jdbc.SQLServerException: The result set is closed. (Element ID:296)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.layoutChildren(HTMLTableBandLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
... 70 more
... 97 more
... 99 more
Re: problem with output parameters [message #908022 is a reply to message #907199] Tue, 04 September 2012 10:56 Go to previous messageGo to next message
Instead of putting it on the onFetch Can you put this script on the
table header row? Do you get the same errors when you do this?
Jason
> 03.09.2012. 15.52
> Data (id = 295):
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> closed.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
> closed.
> at
> at
> at
> ... 82 more
> set is closed.
> at
> at
> at
> at
> ... 84 more
> Table (id = 236):
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> closed.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
> closed.
> at
> at
> at
> ... 82 more
> set is closed.
> at
> at
> at
> at
> ... 84 more
> Data (id = 296):
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> closed.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 70 more
> closed.
> at
> at
> at
> ... 97 more
> set is closed.
> at
> at
> at
> at
> ... 99 more
Re: problem with output parameters [message #912963 is a reply to message #908022] Fri, 14 September 2012 09:46 Go to previous messageGo to next message
Sorry Jason,
Because you replied my message also,I tought that you didn't answer me
I did what you asked (put the script in OnPrepare event for header row) and in preview mode birt showed data from table, but of course not the last output parameter. After showing table it wrote error:
Row (id = 305):
- There are errors evaluating script "var a1 = outputParams["@P_VRATI_NASLOV"];
var a2 = outputParams["@P_VRATI_RACUN"];
var a3 = outputParams["@P_TRANS_RACUN"];
var a4 = outputParams["@P_DOP_PREK"];
var a5 = outputParams["@P_CLASSIC_LIMIT"];
var a6 = outputParams["@P_SALDO_E"];
var a7 = outputParams["@P_NAZIV_FIRMA"];
var a8 = outputParams["@P_NAZIV_KLIJENT"];
var a9 = outputParams["@P_ADRESA_KLIJENTA"];
var a10 = outputParams["@P_PTT_MJESTO"];
out = new PrintWriter( new FileWriter( "c:/test/outputparmsevents.txt", true ) );
out.println( "A1 " + a1);
out.println( "A2 " + a2);
out.println( "A3 " + a3);
out.println( "A4 " + a4);
out.println( "A5 " + a5);
out.println( "A6 " + a6);
out.println( "A7 " + a7);
out.println( "A8 " + a8);
out.println( "A9 " + a9);
out.println( "A10 " + a10);
out.close();":
ReferenceError: "outputParams" is not defined. (/report/body/table[@id="236"]/header/row[@id="305"]/method[@name="onPrepare"]#1) (Element ID:305)
birt.core.JavascriptCommonError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "var a1 = outputParams["@P_VRATI_NASLOV"];
out.close();":
at org.eclipse.birt.report.engine.api.impl.ScriptedDesignHandler.handleOnPrepare(ScriptedDesignHandler.java:452)
at org.eclipse.birt.report.engine.api.impl.ScriptedDesignVisitor.visitRow(ScriptedDesignVisitor.java:351)
at org.eclipse.birt.report.model.api.DesignVisitorImpl$Forwarder.visitRow(DesignVisitorImpl.java:1148)
at org.eclipse.birt.report.model.elements.TableRow.apply(TableRow.java:84)
at org.eclipse.birt.report.model.api.DesignVisitorImpl.apply(DesignVisitorImpl.java:127)
at org.eclipse.birt.report.engine.api.impl.ScriptedDesignVisitor.visitTable(ScriptedDesignVisitor.java:312)
at org.eclipse.birt.report.model.api.DesignVisitorImpl$Forwarder.visitTable(DesignVisitorImpl.java:1100)
at org.eclipse.birt.report.model.elements.TableItem.apply(TableItem.java:91)
at org.eclipse.birt.report.engine.api.impl.ScriptedDesignVisitor.visitReportDesign(ScriptedDesignVisitor.java:108)
at org.eclipse.birt.report.model.api.DesignVisitorImpl$Forwarder.visitReportDesign(DesignVisitorImpl.java:1222)
at org.eclipse.birt.report.model.elements.ReportDesign.apply(ReportDesign.java:65)
at org.eclipse.birt.report.engine.api.impl.EngineTask.prepareDesign(EngineTask.java:1876)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:99)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: org.eclipse.birt.core.exception.CoreException: There are errors evaluating script "var a1 = outputParams["@P_VRATI_NASLOV"];
out.close();":
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.evaluate(JavascriptEngine.java:295)
at org.eclipse.birt.core.script.ScriptContext.evaluate(ScriptContext.java:154)
at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:781)
at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:761)
at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:743)
at org.eclipse.birt.report.engine.api.impl.ScriptedDesignHandler.handleOnPrepare(ScriptedDesignHandler.java:445)
... 65 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "outputParams" is not defined. (/report/body/table[@id="236"]/header/row[@id="305"]/method[@name="onPrepare"]#1)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3654)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3632)
at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRuntime.java:3717)
at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRuntime.java:1758)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java:1697)
at org.mozilla.javascript.gen.c123._c0(/report/body/table[@id="236"]/header/row[@id="305"]/method[@name="onPrepare"]:1)
at org.mozilla.javascript.gen.c123.call(/report/body/table[@id="236"]/header/row[@id="305"]/method[@name="onPrepare"])
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:398)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3065)
at org.mozilla.javascript.gen.c123.exec(/report/body/table[@id="236"]/header/row[@id="305"]/method[@name="onPrepare"])
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.evaluate(JavascriptEngine.java:290)
... 70 more
Re: problem with output parameters [message #913073 is a reply to message #912963] Fri, 14 September 2012 14:08 Go to previous messageGo to next message
I am sorry I mean for you to put it in the onCreate not the onPrepare.
Jason
Re: problem with output parameters [message #915411 is a reply to message #913073] Mon, 17 September 2012 04:18 Go to previous messageGo to next message
All the same. Error is:
Row (id = 305):
out.close();":
ReferenceError: "outputParams" is not defined. (/report/body/table[@id="236"]/header/row[@id="305"]/method[@name="onCreate"]#1) (Element ID:305)
out.close();":
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:244)
at org.eclipse.birt.report.engine.script.internal.RowScriptExecutor.handleOnCreate(RowScriptExecutor.java:64)
at org.eclipse.birt.report.engine.script.internal.OnCreateScriptVisitor.visitRow(OnCreateScriptVisitor.java:167)
at org.eclipse.birt.report.engine.ir.RowDesign.accept(RowDesign.java:108)
at org.eclipse.birt.report.engine.script.internal.OnCreateScriptVisitor.onCreate(OnCreateScriptVisitor.java:73)
at org.eclipse.birt.report.engine.executor.ReportItemExecutor.handleOnCreate(ReportItemExecutor.java:911)
at org.eclipse.birt.report.engine.executor.RowExecutor.execute(RowExecutor.java:83)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.execute(HTMLAbstractLM.java:468)
at org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM.intializeHeaderContent(HTMLListingBandLM.java:98)
at org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM.initialize(HTMLListingBandLM.java:50)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.initialize(HTMLTableBandLM.java:44)
at org.eclipse.birt.report.engine.layout.html.HTMLLayoutManagerFactory.createLayoutManager(HTMLLayoutManagerFactory.java:40)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.createLayoutManager(HTMLReportLayoutEngine.java:138)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:68)
out.close();":
at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:710)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.handleScriptInternal(ScriptExecutor.java:117)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.handleScript(ScriptExecutor.java:104)
at org.eclipse.birt.report.engine.script.internal.RowScriptExecutor.handleOnCreate(RowScriptExecutor.java:56)
... 73 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "outputParams" is not defined. (/report/body/table[@id="236"]/header/row[@id="305"]/method[@name="onCreate"]#1)
at org.mozilla.javascript.gen.c52._c0(/report/body/table[@id="236"]/header/row[@id="305"]/method[@name="onCreate"]:1)
at org.mozilla.javascript.gen.c52.call(/report/body/table[@id="236"]/header/row[@id="305"]/method[@name="onCreate"])
at org.mozilla.javascript.gen.c52.exec(/report/body/table[@id="236"]/header/row[@id="305"]/method[@name="onCreate"])
... 79 more
Re: problem with output parameters [message #915644 is a reply to message #915411] Mon, 17 September 2012 13:19 Go to previous messageGo to next message
Did you open a bugzilla entry for this?
Jason
Re: problem with output parameters [message #915952 is a reply to message #915644] Tue, 18 September 2012 05:34 Go to previous messageGo to next message
no
Re: problem with output parameters [message #916151 is a reply to message #915952] Tue, 18 September 2012 12:11 Go to previous messageGo to next message
Can you? I do not think I can replicate the problem.
Jason
Re: problem with output parameters [message #916749 is a reply to message #916151] Wed, 19 September 2012 08:04 Go to previous messageGo to next message
ok, thank you
Re: problem with output parameters [message #916964 is a reply to message #916749] Wed, 19 September 2012 13:31 Go to previous messageGo to next message
Can you post the bugzilla number here as well?
Jason
Re: problem with output parameters [message #922664 is a reply to message #916964] Tue, 25 September 2012 04:07 Go to previous message
It took me too much time, I did it by populating xml from database and then using that xml as data source. Thank you Jason.
Previous Topic:Create and view reports online
Next Topic:[Solved] Get a text from property file in dataset binding
Current Time: Sat Jul 19 09:08:36 EDT 2025
Powered by FUDForum. Page generated in 0.08345 seconds
