C++ Project Cannot Have Makefile Generated Automatically? [message #912652] |
Thu, 13 September 2012 19:21  |
So I have read:
http://www.eclipse.org/forums/index.php/m/803058/
http://www.eclipse.org/forums/index.php/m/692629/
http://www.eclipse.org/forums/index.php/mv/msg/174901/557137/
The picture attached in the first link is what I see on my screen right now.
Here is what I did:
- use subclipse to import a folder from my svn repository
- with the checkout wizard, I chose "empty C/C++ project"
- I disabled "build automatically"
If I hit the "build" button, it says:
16:16:43 **** Build of configuration Build (GNU) for project native ****
make all
make: *** No rule to make target `all'. Stop.
16:16:43 Build Finished (took 57ms)
Then, I found that I can't ask Eclipse CDT to "generate makefile automatically" in project->properties->builder settings as it is greyed out.
Then, I created a new "makefile project with existing code" project in another workspace to point back to the C++ project above, then I can build correctly.
How come I can't manage my build in Eclipse Juno as I did in Eclipse Galileo?
What's the proper way to checkout a folder and mark the project as a C++ project with eclipse able to generate make file automatically?
Thanks in advance.
FUDForum. Page generated in 0.04032 seconds
