Adding JRadioButton to ButtonGroup generates improper code [message #91094] |
Sat, 14 May 2005 14:40  |
Originally posted by: no.ddress.here
JDK1.5
Eclipse 3.1M6
EMF build I200504141117
GEF Build 3.1M6
VE-runtime-1.1M1
When a JRadioButton is added to a button group, VE generates both of
these import statements:
import javax.swing.JToggleButton$ToggleButtonModel;
import javax.swing.JToggleButton.ToggleButtonModel;
Note the first has a "$".
VE also adds code to the getJRadioButton() method, resulting in:
private JRadioButton getJRadioButton0() {
if (jRadioButton == null) {
JToggleButton.ToggleButtonModel toggleButtonModel3 = new
JToggleButton.ToggleButtonModel();
toggleButtonModel3.setGroup(getButtonGroup());
jRadioButton = new JRadioButton();
jRadioButton.setModel(toggleButtonModel3);
return jRadioButton;
Fix the imports and Save.
In the design view, VE now complains of an Illegal Argument Exception
(IWAV0177E expression too complicated) on toggleButtonModel3 - the
exception is in the tool tip, not in the log files.
Manually changing the method code to:
jRadioButton.getModel().setGroup(getButtonGroup());
eliminates the exception.
Also, is there a reason VE does not automatically generate the manually
revised version of the method, leveraging getModel(), given that
creating the new JRadioButton creates the proper model by default.
Re: Adding JRadioButton to ButtonGroup generates improper code [message #91182 is a reply to message #91094] |
Mon, 16 May 2005 12:29   |
How did you add to a button group? What steps did you do so that we can
track this down, please?
Gerald Rosenberg wrote:
> JDK1.5
> Eclipse 3.1M6
> GEF Build 3.1M6
> VE-runtime-1.1M1
Rich Kulp
Re: Adding JRadioButton to ButtonGroup generates improper code [message #91213 is a reply to message #91182] |
Mon, 16 May 2005 13:41   |
In article <d6aict$9rq$2@news.eclipse.org>, richkulp@us.NO_SPAM.ibm.com
says...
Create a standard VE visual JFrame class.
Drop a radio button on the content panel.
In the radio button property sheet, click model and then the group sub-
property. Use the VE provided property editor to add a button group.
The source should now contain the problematic code.
However, even with my earlier proposed fix, seems that
or any way of adding the group to the individual models does not
work/will prevent the button group from working. Instead, Swing
apparently wants the widget added to the button group:
private ButtonGroup getButtonGroupConvert() {
if (buttonGroupConvert == null) {
buttonGroupConvert = new ButtonGroup();
buttonGroupConvert.add(jRadioButton0);
buttonGroupConvert.add(jRadioButton1);
buttonGroupConvert.add(jRadioButton2);
return buttonGroupConvert;
The non-visual button group bean does not seem to have a
customizer/property editor to add widgets.
> > JDK1.5
> > Eclipse 3.1M6
> > GEF Build 3.1M6
> > VE-runtime-1.1M1
Re: Adding JRadioButton to ButtonGroup generates improper code [message #607768 is a reply to message #91094] |
> JDK1.5
> Eclipse 3.1M6
> GEF Build 3.1M6
> VE-runtime-1.1M1
Rich Kulp
Re: Adding JRadioButton to ButtonGroup generates improper code [message #607770 is a reply to message #91182] |
says...
> > JDK1.5
> > Eclipse 3.1M6
> > GEF Build 3.1M6
> > VE-runtime-1.1M1
FUDForum. Page generated in 0.10455 seconds
