Mysterious double insert (SOLVED, see reply) [message #912370] |
Thu, 13 September 2012 08:54  |
I am facing a strange behaviour of eclipselink 2.1.3: The model consists of
AddressGroup
LinkPersonAddress
Address
AddressGroupMember
when I merge a new AddressGroupMember entity, the entity is merged two times with different ids. The merge is called only one time:
public T merge(T entity)
if (!(entity instanceof User))
* Achtung: Dieses if ist notwendig, weil sonst ein unendlicher Loop
* folgt.
entity.setUser(User.getCurrent());
EntityManager em = getEntityManager();
if (em != null)
try
em.getTransaction().begin();
entity = em.merge(entity);
em.flush();
em.getTransaction().commit();
finally
if (em.getTransaction().isActive())
em.getTransaction().rollback();
return entity;
I checked if the entityManager is called two times but it is not. The entity descriptor is as following:
package ch.eugster.events.persistence.model;
import javax.persistence.AssociationOverride;
import javax.persistence.AssociationOverrides;
import javax.persistence.AttributeOverride;
import javax.persistence.AttributeOverrides;
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.GeneratedValue;
import javax.persistence.Id;
import javax.persistence.JoinColumn;
import javax.persistence.ManyToOne;
import javax.persistence.Table;
import javax.persistence.TableGenerator;
import org.eclipse.persistence.annotations.Customizer;
@Entity
@Table(name = "events_address_group_member")
@AssociationOverrides({ @AssociationOverride(name = "user", joinColumns = @JoinColumn(name = "address_group_member_user_id")) })
@AttributeOverrides({ @AttributeOverride(name = "inserted", column = @Column(name = "address_group_member_inserted")),
@AttributeOverride(name = "updated", column = @Column(name = "address_group_member_updated")),
@AttributeOverride(name = "deleted", column = @Column(name = "address_group_member_deleted")),
@AttributeOverride(name = "version", column = @Column(name = "address_group_member_version")) })
@Customizer(DeletedFilter.class)
public class AddressGroupMember extends AbstractEntity
* References
@ManyToOne(optional = false)
@JoinColumn(name = "address_group_member_address_group_id", referencedColumnName = "address_group_id")
private AddressGroup addressGroup = null;
@JoinColumn(name = "address_group_member_address_id", referencedColumnName = "address_id")
private Address address;
@ManyToOne
@JoinColumn(name = "address_group_member_pa_link_id", referencedColumnName = "pa_link_id")
private LinkPersonAddress link = null;
* Data
@Id
@Column(name = "address_group_member_id")
@GeneratedValue(generator = "events_address_group_member_id_seq")
@TableGenerator(name = "events_address_group_member_id_seq", table = "events_sequence")
private Long id;
private AddressGroupMember()
super();
private AddressGroupMember(final AddressGroup addressGroup)
super();
this.setAddressGroup(addressGroup);
addressGroup.addAddressGroupMember(this);
private AddressGroupMember(final AddressGroup addressGroup, final Address address)
super();
this.setParent(null, address);
private AddressGroupMember(final AddressGroup addressGroup, final LinkPersonAddress link)
super();
this.setParent(link, link.getAddress());
public AddressGroupMember copy(final AddressGroup addressGroup)
AddressGroupMember copy = AddressGroupMember.newInstance(addressGroup);
copy.setParent(this.getLink(), this.getAddress());
return copy;
public Address getAddress()
return address;
public AddressGroup getAddressGroup()
return this.addressGroup;
public Long getId()
return this.id;
public LinkPersonAddress getLink()
return this.link;
public void setAddressGroup(final AddressGroup addressGroup)
this.propertyChangeSupport.firePropertyChange("addressGroup", this.addressGroup,
this.addressGroup = addressGroup);
public void setId(final Long id)
this.propertyChangeSupport.firePropertyChange("id", this.id, this.id = id);
public void setParent(final LinkPersonAddress link, final Address address)
this.link = link;
if (link != null)
// link.addAddressGroupMember(this);
this.address = address;
if (address != null)
// address.addAddressGroupMember(this);
public static AddressGroupMember newInstance()
return (AddressGroupMember) AbstractEntity.newInstance(new AddressGroupMember());
public static AddressGroupMember newInstance(final AddressGroup addressGroup)
return (AddressGroupMember) AbstractEntity.newInstance(new AddressGroupMember(addressGroup));
public static AddressGroupMember newInstance(final AddressGroup addressGroup, final Address address)
return (AddressGroupMember) AbstractEntity.newInstance(new AddressGroupMember(addressGroup, address));
public static AddressGroupMember newInstance(final AddressGroup addressGroup, final LinkPersonAddress link)
return (AddressGroupMember) AbstractEntity.newInstance(new AddressGroupMember(addressGroup, link));
Has anyone any idea whatis going on here? Thank you!
[Updated on: Thu, 13 September 2012 09:21] by Moderator
FUDForum. Page generated in 0.04303 seconds
