Re: [XCore] derived feature, manual code [message #912224 is a reply to message #912183] |
Thu, 13 September 2012 02:47  |
Yes, although for dynamic delegation, reflective calls to eGet will
bypass any logic in the generated accessors, so that doesn't really work
well even if we generate the body properly. For reflective delegation
is should be supported because it's properly supported when you hand
modify the generated implementation. Your problem is related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=385634. But this is a
little trickier because the implementation should be in the basicGet and
it shouldn't resolve the proxy.
On 13/09/2012 7:13 AM, M. Herrmann wrote:
> So intention is, that the body specified in the XCore overrides any
> default implementation, no matter what type of featureDelegation?
FUDForum. Page generated in 0.04141 seconds
