Home » Modeling » TMF (Xtext) » problem for define dsl
problem for define dsl [message #908964] |
Thu, 06 September 2012 06:04  |
I'm working on a DSL but i have a problem with my grammar
I want to define for example:
dcl pc%
print=1: tabv(1),(W10),(*(*)N6Z4),(Z2.Z2),(Z8.Z5,Z3,Z5),pc
So, I've started with the following construct:
CompilationUnit:
abalElements+=AbalElement*;
AbalElement:
Print|Declaration|Etiquette|Constant ;
Etiquette /*returns EtiquetteSymbol*/:
'&'name=ID
Print:
'print='numLog=INT ('&'etiquette=[Etiquette])?':'(datas+=Data3 ((',') datas+=Data3)* )?
Data3:
Expression|Directive2|Format2
Directive2:
Atb|Bell|Clear|Page|Home|Paint|Tab|Tabv
Format2:
'('inputField2=InputField2')'
InputField2:
CommandeID2|CommandeQualifiedNameComma|CommandeQualifiedName|CommandeIdComma
CommandeID2:
{CommandeID2} commande+=('E'|'U'|'W'|'Z'|'N'|'O'|'L'|'R'|'$'|'C'|'I'|'H'|'+'|'-'|'.'|'V'|'S'|'*'|'X'|'T'|'/'|'/0'|'1'|'2'|'3'|'4'|'5'|'6'|'7'|'8'|'9')*
Tabv:'tabv''('lignes=INT')'//('='Variable=[Symbol])?
Tab: 'tab''('col=INT (','lig=INT)?')'//('='Variable=[Symbol])?
Paint:'paint' '('text=INT (','background=INT)?')'//('='Variable=[Symbol])?
Home:{Home}'home'//('='Variable=[Symbol])?
Clear:
{Clear}'clear'//('='Variable=[Symbol])?
Page:
{Page}'page'//('='Variable=[Symbol])?
Bell:
{Bell}'bell'//('='Variable=[Symbol])?
Atb:
'atb''('attribut=INT')'//('='Variable=[Symbol])?
CommandeQualifiedNameComma:
commande=QualifiedNameDotComma
CommandeQualifiedName:
CommandeIdComma:
commande=QualifiedNameComma
Declaration:
PointerDeclaration|VariableDeclaration|PointerProc//|VariableDeclarationProc//|ProcPointer
PointerDeclaration returns Symbol:
'ptr'name = ID type=Type /*( | ('like' variable=[Symbol |Type])) */
PointerProc returns Symbol:
'ptr proc' name = ID
VariableDeclaration returns Symbol:
'dcl' name = ID type=Type/*( | ('like' variable=[VariableDeclaration |Type]))*/
('endloc')?('[,S]')?
Constant returns Symbol:
'const' variable=VariableDeclaration
Type:
ShortNumericType | NumericType | StringType |BCDType
//|PointerProc
ShortNumericType:
{ShortNumericType}'#';
NumericType:
{NumericType}'%';
StringType:
{StringType}'$'('='size=INT)?
BCDType:
{BCDType}('='size=INT)?;
Expression :
CompareOperator;
CompareOperator returns Expression:
ConditionalOR(( {Equality2.left=current} '='|{Equality.left=current}'=='|{NoInclusion.left=current}'!='|{Different.left=current}'<>'|{Inferrior.left=current}'<'|{Superior.left=current}'>'|{SuperiorOrEqual.left=current}'>='|{InferriorOrEqual.left=current}'<=') right=ConditionalOR)*;
ConditionalOR returns Expression:
Addition (({ConditionalOR.left=current} 'or'|{ConditionalOX.left=current} 'ox'|{ConditionalAND.left=current} 'and'|{ConditionalNOT.left=current} 'not') right=Addition)*;
Addition returns Expression:
Multiplication (({Plus.left=current} '+' | {Minus.left=current} '-') right=Multiplication)*;
Multiplication returns Expression:
//CallExpression (({Multi.left=current} '*' | {Div.left=current} '/') right=CallExpression)*;
PrimaryExpression (({Multi.left=current} '*' | {Div.left=current} '/') right=PrimaryExpression)*;
//CallExpression returns Expression :
//PrimaryExpression (({Call.funcExpr=current} procedure=[Procedure] /*','*/) right=PrimaryExpression )*;
//PrimaryExpression (({Call.callExpr=current} symbol=[Symbol] /*procedure =[Procedure]*/ ('('argument+=[VariableDeclaration] (',' argument+=[VariableDeclaration])* ')')? ) right=PrimaryExpression )*;
PrimaryExpression returns Expression:
NumericInt|NumericReal|StringLiteral// |ExplicitCall
//| VariableOperande
|SymbolRef
| '(' Expression ')'
//ExplicitCall returns Call : {Call} explicitKeyword ?= 'call' procedure=[Procedure] ('('argument+=[VariableDeclaration] (',' argument+=[VariableDeclaration])* ')')?;
SymbolRef:
CallOrVariableSymbolRef|PauseSymbolRef|AliasSymbolRef|LikeSymbolRef
//|ProcPointer//|ExternEventCall
CallOrVariableSymbolRef:
('call')? symbol=[Symbol|ID] ("(" (arguments+=Expression)? ( "," arguments+=Expression)* ")")?(':erreur')?
PauseSymbolRef:
'pause' symbol=[Symbol|ID]//|Constant
AliasSymbolRef:
'alias' symbol=[Symbol|ID]
LikeSymbolRef:
'like' variable=[Symbol |ID]
StringLiteral:
stringValue=STRING
NumericInt:
value=INT;
NumericReal:
value=REAL;
terminal INT returns ecore::EInt: ('0'..'9')+;
terminal REAL returns ecore::EDouble : INT '.' INT;
//QualifiedName2 hidden(): ('E'|'U'|'W'|'Z'|'N'|'O'|'L'|'R'|'C'|'I'|'H'|'V'|'S'|'X'|'T'|'$'|'0'|'1'|'2'|'3'|'4'|'5'|'6'|'7'|'8'|'9')*;
terminal ID : ('a'..'z'|'A'..'Z'|'$'|'_') ('a'..'z'|'A'..'Z'|'$'|'_'|'0'..'9')*;
QualifiedName hidden(): ID '.' ID;
QualifiedName2 hidden():ID ('?' ID)+;
QualifiedNameDot hidden(): ID ('.' ID)+;
QualifiedNameComma hidden(): ID (',' ID)+;
QualifiedNameDotComma hidden(): QualifiedNameDot (','QualifiedNameDot)+;
terminal STRING :
'"' ( '\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') | !('\\'|'"') )* '"' |
"'" ( '\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') | !('\\'|"'") )* "'"
terminal SL_COMMENT : (';') !('\n'|'\r')* ('\r'? '\n')?;
terminal WS : (' '|'\t'|'\r'|'\n')+;
terminal ANY_OTHER: .;
But when i defined something like this i have problem
I need to put space between command but it's not that i want
And i can't define ID like E or U or...T
the same problem with INT i can't define a int value like 1 or 2 or...9
I don't know what is the solution
Maybe somebody has an idea or can point me into the right direction? Thanks in advance!
Jérôme
Report message to a moderator
Re: problem for define dsl [message #911926 is a reply to message #911879] |
Wed, 12 September 2012 11:44   |
The problems are probably caused by overlapping terminals. If you have a
keyword '1', then you can never have an INT that is 1.
Command : {Command} 'commandKeyword' '->' command = CommandType ;
CommandType: INT | ID ;
Then you associate a value converter for CommandType that issues errors
if the string it gets is not ('1'|'2'|'A'|'B').
Alternatively, you don't add a converter, and instead just validate that
the command string is ('1'|'2'|'A'|'B'). This way you can offer a quick
fix if the user entered say 'a'.
With the suggested scheme you will not however automatically get code
completion since the framework can not guess what is acceptable, so you
need to customize that.
Small note, it is better to use separate keywords; i.e. 'print' '=' than
running them together - esp if the string contains whitespace, or if an
operator is also a free standing operator. If you separate them, it also
means that whitespace is tolerated between the tokens unless you
instruct Xtext to not hide whitespace.
Hope that helps.
- henrik
On 2012-12-09 15:54, Laigle jérôme wrote:
> Other example
> My dsl:
> CompilationUnit:
> AbalElement:
> Print|Command
> Print:
> 'print='numLog=INT (label=[Label])? ;
> Command:
> {Command} 'commandKeyword->' command=('1'|'2'|'A'|'B')
> Label :
> '&'name=ID
> terminal STRING : '"' ( '\\'
> test with xtend:
> @RunWith(typeof(XtextRunner)) @InjectWith(typeof(LanguageInjectorProvider))
> class test{
> @Inject extension ParseHelper<CompilationUnit>
> @Test def void testAsk2() {
> val compilationUnit = '''
> print=1234
> '''.parse
> Assert::assertTrue(compilationUnit.abalElements.size>0);
> val abalElement = compilationUnit.abalElements.get(0)
> val print = abalElement as Print
> Assert::assertEquals(1234,print.numLog)//test is ok
> @Test def void testAsk() {
> print=1
> '''.parse
> val abalElement =
> compilationUnit.abalElements.get(0)//assertion failed error
> Assert::assertEquals(1,print.numLog)
> I can't reuse a command in int or id
> i don't know how i can define
> Thanks in advance!
> Best regards,
> Jérôme
Re: problem for define dsl [message #918229 is a reply to message #917839] |
Thu, 20 September 2012 17:33   |
On 2012-20-09 15:39, Laigle jérôme wrote:
> thank you for your help
> i tried to do something to validate
> i defined java validator like that:
> public class LanguageJavaValidator extends AbstractLanguageJavaValidator {
> String[] validCommands = {"E","Z"};
> @Check
> public void checkValidCommand(Command cmd) {
> for(String commande:cmd.getCommandKey()){
> if(!Arrays.asList(validCommands).contains(commande)){
> warning("Invalid Command: "+commande,
> LanguagePackage.eINSTANCE.getCompilationUnit_AbalElements());
> My dsl:
> CompilationUnit:
> AbalElement:
> Print|Command
> Print:
> 'print' '=' numLog=INT (label=[Label])? ;
> Command:
> {Command} 'commandKeyword' '->' commandKey+=ID
> Label :
> '&'name=ID
> but when i realised test it's not ok
> @Test def void testAsk3() {
> commandKeyword-> AB
> '''.parse
> val commande = abalElement as Command
> Assert::assertEquals("AB",commande.commandKey.get(0))
> this test should be false but it's ok
> i don't find many example for implement java validator maybe it's not a
> good defined Best regards,
> Jérôme
You need to check if there are errors. You got exactly what was parsed,
so naturally the thing you are checking contains "AB".
You need to look at how to assert that a warning is present.
It is only if there are syntax errors (can not parse this) that it will
fail on its own.
If it was not this way; you could not read the parsed (non validation
conforming input) in a semantic way, and it would be very difficult to
implement quick fixes etc.
Also, make sure your validation logic is invoked as you expect. (Set a
breakpoint, or do a printout or something).
Hope that helps.
- henrik
Re: problem for define dsl [message #921743 is a reply to message #918229] |
Mon, 24 September 2012 07:43   |
thanks for the quick reply
i tried to parse warning
public class ParseHelper3<T extends EObject> extends ParseHelper<T> {
@Inject
private IResourceFactory resourceFactory;
@Inject
private Provider<XtextResourceSet> resourceSetProvider;
public List<Diagnostic> parseToWarning(InputStream in, URI uriToUse, Map<?, ?> options, ResourceSet resourceSet) {
Resource resource = resourceFactory.createResource(uriToUse);
resourceSet.getResources().add(resource);
try {
resource.load(in, options);
if (resource.getWarnings().size() > 0) {
return resource.getWarnings();
throw new IllegalStateException();
} catch (IOException e) {
throw new WrappedException(e);
public List<Diagnostic> parseToWarning(CharSequence text) throws Exception {
return parseToWarning(text, resourceSetProvider.get());
public List<Diagnostic> parseToWarning(CharSequence text, ResourceSet resourceSetToUse) throws Exception {
return parseToWarning(getAsStream(text), computeUnusedUri(resourceSetToUse), null, resourceSetToUse);
public List<Diagnostic> parseToWarning(CharSequence text, URI uriToUse, ResourceSet resourceSetToUse) throws Exception {
return parseToWarning(getAsStream(text), uriToUse, null, resourceSetToUse);
Java validator:
@Check
if(!Arrays.asList(validCommands).containsAll(Arrays.asList(commande))){
warning("Invalid Command: ", LanguagePackage.Literals.COMMAND__COMMAND_KEY);
//eINSTANCE.getCompilationUnit_AbalElements()
And my test :
class WarningTest {
@Inject extension ParseHelper3<CompilationUnit>
val diagnostic =
parseToWarning(
commandKeyword-> AB
Assert::assertNotNull(diagnostic)
Assert::assertEquals(1,diagnostic.size)
@Test def void testAsk4() {
val diagnostic =
parseToWarning(
commandKeyword-> E
Assert::assertEquals(0,diagnostic.size)
but test failed
Jérôme
Re: problem for define dsl [message #921876 is a reply to message #921743] |
Mon, 24 September 2012 10:03  |
What I meant was that you need to assert that there are no warning or
errors in your unit test.
The errors and warnings you issue in your validator ends up as warnings
and errors in the Resource. How you assert these in the test depends on
how you have written your tests, if you are using the Xtext framework etc.
- henrik
Current Time: Sat Jul 19 11:53:52 EDT 2025
Powered by FUDForum. Page generated in 0.04359 seconds
