Eclipse keyboard shortcuts load/save [message #911847] |
Wed, 12 September 2012 08:51  |
I am passing through an Eclipse keyboard shortcut customization fiasco.
I was using Indigo for c++ and Java, and now want to use Juno.
I want to keep my shortcuts.
I tried the import/export facility but many shortcuts don't work. They seem to be bound to the respective commands in Preferences > Keys, but they don't work. Also, there are no visible conflicts. For example, I have Shift+Ctrl+S bound to SVN Sychronize, but when I press it, I get a small window in the bottom right corner showing that this shortcut coflicts with 'Save All'. However, when filtering for Shift+Ctrl+S in Keys, I see no conflict for this key.
Started to dig inside workspace configuration files, specifically <workspace>/.metadata/.plugins/org.eclipse.core.runtime/.settings/org.eclipse.ui.workbench.prefs. There, I see that I have 2 expected key bindings:
<keyBinding commandId\="org.eclipse.search.ui.performTextSearchFile" contextId\="org.eclipse.ui.textEditorScope" keyConfigurationId\="org.eclipse.ui.defaultAcceleratorConfiguration" keySequence\="CTRL+SHIFT+S"/>
<keyBinding commandId\="org.eclipse.team.svn.ui.command.SynchronizeCommand" contextId\="org.eclipse.ui.contexts.window" keyConfigurationId\="org.eclipse.ui.defaultAcceleratorConfiguration" keySequence\="CTRL+SHIFT+S"/>
... one being for Synchronizing a project when it's selected in Project Explorer, and the other for searching a word using editor scope. They don't conflict with each other and worked like a charm in previous version of Eclipse, Indigo.
I notice 2 other bindings containing SHIFT+CTRL+S:
<keyBinding contextId\="org.eclipse.ui.contexts.window" keyConfigurationId\="org.eclipse.ui.defaultAcceleratorConfiguration" keySequence\="CTRL+SHIFT+S"/>
After removing these from the file, and restarting Eclipse, magic happens: the Preferences > Keys dialog shows 'SVN Synchronize' conflict with 'Save All'. Now I can un-bind the 'Save all' command and voila - it works.
Digging some more, I find that this triggered a modification of a different config file, <workspace>/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi, specifically it added the "deleted" bit for the Save All binding:
<bindings xmi:id="_u5UL8_vnEeG8LJ5AnbQ0RQ" keySequence="CTRL+SHIFT+S" command="_u4d3hfvnEeG8LJ5AnbQ0RQ">
<tags>deleted</tags>
</bindings>
... the command _u4d3hfvnEeG8LJ5AnbQ0RQ being, well, 'Save All'.
My conclusion is that migrating shortcuts is difficult, if possible at all. Impossible with import/export utility and a nightmare using config files - because of their intricate format and the fact they interact with each other in magical ways.
Question is obvious, did any of you pull this off?
FUDForum. Page generated in 0.34735 seconds
