Home » Eclipse Projects » Eclipse Platform » workbench status line
workbench status line [message #90651] Wed, 09 July 2003 21:17 Go to next message
Please help. I am trying to create a progress monitor on the status line
of workbench. I successfully created one with IRunnableWithProgress.
However, I cannot use the approach because the request to control the
progress monitor comes from outside the "run".
What would be an easy way to create a progress monitor on the workbench
statue line directly? I found that
ApplicationWindow.getStatusLineManager().getProgressMonitor( )
would be a good candidate, but I couldn't get to it from the "workbench"
(IWorkbench or IWorkbenchWindow).
What am I missing?
Thanks in advance.
JK
Re: workbench status line [message #90799 is a reply to message #90651] Thu, 10 July 2003 03:32 Go to previous messageGo to next message
Get the site of your editor (IEditorSite) or view (IViewSite) and then
getViewSite().getActionBars().getStatusLineManager()
HTH
Dani
Re: workbench status line [message #91060 is a reply to message #90799] Thu, 10 July 2003 12:02 Go to previous messageGo to next message
> HTH
> Dani
Hi Dani,
Thanks for the reply. However, I am trying to provide a progress meter
service to an external component. So, I normally start with
PlatformUI.getWorkbench()
Is there a way to get IEditorSite from IWorkbench?
JK
Re: workbench status line [message #91147 is a reply to message #91060] Thu, 10 July 2003 12:51 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
Look at IWorkbenchWindow.run(boolean, boolean, IRunnableWithProgress) method
(actually, this method is on IRunnableContext which IWorkbenchWindow
extends)
Simon :-)
"JK Lah" <jk.lah@intel.com> wrote in message
news:bek2lv$dkq$1@eclipse.org...
line
"workbench"
> > HTH
> > Dani
> Hi Dani,
> JK
Re: workbench status line [message #91162 is a reply to message #91147] Thu, 10 July 2003 13:23 Go to previous messageGo to next message
Thanks for the info, but I am trying to avoid using IRunnableWithProgress
and create IProgressMonitor object directly on the status line of
workbench. Since my request to create Progress monitor comes from an
external component, I couldn't make the IRunnableWithProgress working.
The "run" function cannot return while the progress monitor is up. If I
create a separate thread for the "run", then it is not a UI thread to
update the progress monitor.
All I want to do is to create a progress monitor widget on the status line
of workbench and control it. Conceptually, it sounds simple, but I cannot
figure out how to get the status line from IWorkbench.
JK
> extends)
> Simon :-)
> line
> "workbench"
> > > HTH
> > > Dani
> > Hi Dani,
> > JK
Re: workbench status line [message #91177 is a reply to message #91162] Thu, 10 July 2003 13:33 Go to previous message
There is no API for you to add something to the status bar that is global to
the window. Only the active view/editor has control of the status line.
Simon :-)
news:bek7dm$j3c$1@eclipse.org...
> JK
method
> > extends)
> > Simon :-)
status
> > line
the
workbench
> > "workbench"
then
> > > > HTH
> > > > Dani
> > > Hi Dani,
meter
> > > JK
Previous Topic:basic framework question
Next Topic:Re: ActionSet
Current Time: Sat Jul 19 19:10:39 EDT 2025
Powered by FUDForum. Page generated in 0.03015 seconds
