Home » Eclipse Projects » Equinox » Eclipse Will Not Run, Shows Large Log File Instead(After unzipping any version of Eclipse, 32 or 64 bit, instead of running Eclipse shows an error screen and only an error screen)
Eclipse Will Not Run, Shows Large Log File Instead [message #699561] Thu, 21 July 2011 15:19 Go to next message
Before you ask - yes I read through the eclipse.ini thread before posting this, and I even tried making a new workspace and changing the config.ini file to go there, but didn't work.
I cannot run any version of eclipse, 3.6 or 3.7, 32bit or 64bit...
every time I unzip and then double click on the Eclipse application it shows this error screen:
index.php/fa/3429/0/
and that number XXXXXXX.log changes each time (a different log file is created, with different errors)
The very first log file created is over 1MB large and WAY too long to include here (11000+ lines)
All the log files are stored in the configuration folder.
The next time i click and try to run Eclipse, smaller log files (~12KB) are created, and repeated each and every time I try to open it - the following is contained in those log files:
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-07-21 15:09:52.540
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unknown repository type at file:/eclipse/configuration/org.eclipse.osgi/bundles/115/data/listener_1925729951/.
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:393)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.doCreateRepository(AbstractRepositoryManager.java:282)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.createRepository(MetadataRepositoryManager.java:41)
	at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.initializeMetadataRepository(RepositoryListener.java:109)
	at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.<init>(RepositoryListener.java:59)
	at org.eclipse.equinox.internal.p2.reconciler.dropins.DropinsRepositoryListener.<init>(DropinsRepositoryListener.java:82)
	at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.watchDropins(Activator.java:532)
	at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start(Activator.java:172)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:389)
	at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1130)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1005 2011-07-21 15:09:52.541
!MESSAGE Unknown repository type at file:/eclipse/configuration/org.eclipse.osgi/bundles/115/data/listener_1925729951/.
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2011-07-21 15:09:52.552
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start() of bundle org.eclipse.equinox.p2.reconciler.dropins.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
Caused by: java.lang.IllegalStateException: Could not create metadata repository for: file:/eclipse/configuration/org.eclipse.osgi/bundles/115/data/listener_1925729951/
	at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.initializeMetadataRepository(RepositoryListener.java:112)
	... 12 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2011-07-21 15:09:53.148
!MESSAGE Application error
!STACK 1
org.osgi.service.application.ApplicationException: No application id has been found.
	at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:262)
	at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
I have the latest versions of Java and am running Mac OS X 10.6.8
I tried running eclipse -clean -> that doesn't work either, it just opens terminal and then exits, returning 0.
please help
Update 7/22 - tried removing (after saving and backing up) org.eclipse.eclipse.plist as suggested by a friend, didn't work... so i put that plist back, still nothing working
[Updated on: Fri, 22 July 2011 20:12] by Moderator
Re: Eclipse Will Not Run, Shows Large Log File Instead [message #699872 is a reply to message #699561] Fri, 22 July 2011 10:10 Go to previous messageGo to next message
Moved this to the Equinox group since it looks like p2 gurus might be able to shed some light.
Re: Eclipse Will Not Run, Shows Large Log File Instead [message #701279 is a reply to message #699872] Sun, 24 July 2011 18:59 Go to previous messageGo to next message
I have had exactly the same issue on a mac also and would really like it if someone could give us some idea of how to resolve this issue. Confused
Re: Eclipse Will Not Run, Shows Large Log File Instead [message #702454 is a reply to message #701279] Tue, 26 July 2011 07:49 Go to previous messageGo to next message
Same issue here.
Had no problems earlier with Fedora 12, JDK 5, Eclipse Galileo. Just needed a "tar -xvf" then
Migrated to Fedora 15, and continuously getting the same error as you. Spent a whole frustrating day on it. Tried with Galileo & Indigo. Tried with .tar.gz as well as "yum install eclipse". Keeps showing the same log file error message.
Here is my error:
!SESSION 2011-07-26 16:46:19.456 -----------------------------------------------
eclipse.buildId=M20110210-1200
java.version=1.6.0_25
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-07-26 16:46:20.167
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unknown repository type at file:/home/bala/.eclipse/org.eclipse.platform_3.6.1_155965261/configuration/org.eclipse.osgi/bundles/79/data/listener_1925729951/.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:391)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.doCreateRepository(AbstractRepositoryManager.java:280)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.initializeMetadataRepository(RepositoryListener.java:123)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.initialize(RepositoryListener.java:73)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.<init>(RepositoryListener.java:68)
at org.eclipse.equinox.internal.p2.reconciler.dropins.DropinsRepositoryListener.<init>(DropinsRepositoryListener.java:53)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.watchDropins(Activator.java:489)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:459)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:440)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1005 2011-07-26 16:46:20.168
!MESSAGE Unknown repository type at file:/home/bala/.eclipse/org.eclipse.platform_3.6.1_155965261/configuration/org.eclipse.osgi/bundles/79/data/listener_1925729951/.
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2011-07-26 16:46:20.173
!MESSAGE
!STACK 0
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
Caused by: java.lang.IllegalStateException: Could not create metadata repository for: file:/home/bala/.eclipse/org.eclipse.platform_3.6.1_155965261/configuration/org.eclipse.osgi/bundles/79/data/listener_1925729951/
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.initializeMetadataRepository(RepositoryListener.java:126)
... 11 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2011-07-26 16:46:20.213
!STACK 1
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
Re: Eclipse Will Not Run, Shows Large Log File Instead [message #716531 is a reply to message #702454] Wed, 17 August 2011 11:58 Go to previous messageGo to next message
same also here...i can't run eclipse helios..
here's the error..
!SESSION 2011-08-18 00:40:10.624 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0_23
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_PH
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2011-08-18 00:40:11.369
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.equinox.internal.simpleconfigurator.Activator for bundle org.eclipse.equinox.simpleconfigurator is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:156)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:751)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/osgi/framework/internal/core/BundleLoader
at eclipseme.core.hooks.EclipseMEClassLoadingHook.createClassLoader(EclipseMEClassLoadingHook.java:282)
at org.eclipse.osgi.baseadaptor.BaseData.createClassLoader(BaseData.java:94)
at org.eclipse.osgi.internal.loader.BundleLoader.createBCL(BundleLoader.java:842)
at org.eclipse.osgi.internal.loader.BundleLoader.createBCLPrevileged(BundleLoader.java:831)
at org.eclipse.osgi.internal.loader.BundleLoader.createClassLoader(BundleLoader.java:377)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:333)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:149)
... 11 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.osgi.framework.internal.core.BundleLoader
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 19 more
Root exception:
... 19 more
!ENTRY org.eclipse.equinox.common 4 0 2011-08-18 00:40:11.371
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.core.internal.runtime.Activator for bundle org.eclipse.equinox.common is invalid
... 11 more
Root exception:
!ENTRY org.eclipse.equinox.ds 4 0 2011-08-18 00:40:11.372
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.equinox.internal.ds.Activator for bundle org.eclipse.equinox.ds is invalid
... 11 more
Root exception:
!ENTRY org.eclipse.equinox.event 4 0 2011-08-18 00:40:11.373
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.equinox.internal.event.Activator for bundle org.eclipse.equinox.event is invalid
... 11 more
Root exception:
!ENTRY org.eclipse.core.runtime 4 0 2011-08-18 00:40:11.388
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.core.internal.runtime.PlatformActivator for bundle org.eclipse.core.runtime is invalid
... 11 more
Root exception:
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2011-08-18 00:40:11.395
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.equinox.internal.p2.reconciler.dropins.Activator for bundle org.eclipse.equinox.p2.reconciler.dropins is invalid
... 11 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2011-08-18 00:40:11.401
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503 [1] is not active.
!ENTRY org.eclipse.osgi 4 0 2011-08-18 00:40:11.590
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Re: Eclipse Will Not Run, Shows Large Log File Instead [message #911085 is a reply to message #699561] Mon, 10 September 2012 20:05 Go to previous message
Hi, I dont know whether the issue has already been solved or not. But what i did was i have removed the total java-jdk and every related thing from my pc restarted the machine. then installed java-jdk latest/stable version and changed classpath and everything.eclipse was again reinstalled having removed all old versions. ( mind one thing in your mind..put a system restore point BEFORE DO EVERYTHING.. (Control Panel\System and Security\System then system protection then create>..
then restarted the machine. everthing worked perfectly ok. GOOD LUCK .... Razz
Previous Topic:how to read a file in another plugin?
Next Topic:Problem getting started
Current Time: Sun Jul 20 03:42:40 EDT 2025
Powered by FUDForum. Page generated in 0.04097 seconds
