VM arguments [message #91008] |
Fri, 13 May 2005 15:22  |
Originally posted by: schesvo.cs.ndsu.edu
I am trying to build a standalone application with the visual editor. I
create
an SWT shell with no problem. The following code is generated:
* Created on May 12, 2005
* TODO To change the template for this generated file go to
* Window - Preferences - Java - Code Style - Code Templates
package testPackage;
* @author Doug Schesvold
* TODO To change the template for this generated type comment go to
public class TestStandalone {
private org.eclipse.swt.widgets.Shell sShell = null;
/* Before this is run, be sure to set up the following in the launch
configuration
* (Arguments->VM Arguments) for the correct SWT library path.
* The following is a windows example:
-Djava.library.path=" installation_directory\plugins\org.eclipse.swt.win32_3.0.0\o s\win32\x86 "
org.eclipse.swt.widgets.Display display =
org.eclipse.swt.widgets.Display.getDefault();
TestStandalone thisClass = new TestStandalone();
thisClass.createSShell() ;
thisClass.sShell.open();
while (!thisClass.sShell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep ();
display.dispose();
* This method initializes sShell
private void createSShell() {
sShell = new org.eclipse.swt.widgets.Shell();
sShell.setSize(new org.eclipse.swt.graphics.Point(300,200));
sShell.setText("Shell");
I follow the instructions in the comment concerning VM arguments and enter
the following in the VM arguments section of the run configuration:
-Djava.library.path=C:\Program
Files\eclipse\plugins\org.eclipse.swt.win32_3.0.2\os\win32\x 86
When I enter a space between "Program" and "Files" it puts in a newline.
When I click run, I get a message that says:
"Could not find the main class. Program will exit"
and an error message that says:
"java.lang.NoClassDefFoundError:
Files\eclipse\plugins\org/eclipse/swt/win32_3/0/2\os\win32\x 86 "
It seems to be having a problem with " " and "." in the path. It seems to
be
substituting a "/" for the "."
Are these special characters that need to be quoted somehow?
The eclipse version is 3.0.2 and the VE version is 1.0.2.1.
Doug.
FUDForum. Page generated in 1.05373 seconds
