Home » Language IDEs » Java Development Tools (JDT) » Where do I find the javafamily example plugin?
Where do I find the javafamily example plugin? [message #90916] Fri, 29 August 2003 16:27 Go to next message
Where do I find the javafamily example plugin refered at New and Eclipse
3.0 M3 Noteworthy document?
Re: Where do I find the javafamily example plugin? [message #90930 is a reply to message #90916] Fri, 29 August 2003 16:51 Go to previous messageGo to next message
Originally posted by: vkyr.nospam-ision.net
"Emerson Cargnin" <echofloripa@bol.com.br> schrieb im Newsbeitrag
news:biocul$hvg$1@eclipse.org...
It's inside the "eclipse-examples-3.0M3-xxx.xxx" download and can be enabled
after installing the eclipse examples. As an alternative it can also be
downloaded from the Eclipse CVS online server.
-Valentino
Re: Where do I find the javafamily example plugin? [message #90960 is a reply to message #90930] Fri, 29 August 2003 19:22 Go to previous messageGo to next message
I didn't find how to enable it..
> -Valentino
Re: Where do I find the javafamily example plugin? [message #90974 is a reply to message #90960] Fri, 29 August 2003 19:56 Go to previous messageGo to next message
news:bion8d$q6t$1@eclipse.org...
Preferences -> Java -> Work In Progress -> Refactoring -> [x] Enable
Reafctoring Participants...
Re: Where do I find the javafamily example plugin? [message #94062 is a reply to message #90960] Wed, 10 September 2003 12:47 Go to previous message
You don't have to enable it. Once it's installed it is enabled. What you
have to enable are the refactoring participants (see Valentino's answer).
HTH
Dani
>>-Valentino
Previous Topic:Broken: code-completion, source open decleration, automatic imports
Next Topic:pointing a class to a project
Current Time: Sun Jul 20 04:36:35 EDT 2025
Powered by FUDForum. Page generated in 0.25242 seconds
