Home » Newcomers » Newcomers » The server configuration is missing or invalided.
The server configuration is missing or invalided. [message #909310] Thu, 06 September 2012 19:29 Go to next message
I am getting the following message, but not sure how to fix it.
The Tomcat server configuration at \Servers\Tomcat v7.0 Server at localhost-config is missing. Check the server for errors.
I bring up the General Information and attempt to browse. but it displays my projects.
Not sure where do I go from here. Looking for instructions on how to set this up.
Howard
Re: The server configuration is missing or invalided. [message #909314 is a reply to message #909310] Thu, 06 September 2012 19:41 Go to previous messageGo to next message
Now getting this.
Sep 06, 2012 4:40:56 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre7\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre7/bin/client;C:/Program Files/Java/jre7/bin;C:/Program Files/Java/jre7/lib/i386;c:\oc4j\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Java\jdk1.7.0_05\bin;C:\Program Files\Eclipse JEE Indigo\eclipse;;.
Sep 06, 2012 4:40:57 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-8080"]
Sep 06, 2012 4:40:58 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["ajp-bio-8009"]
Sep 06, 2012 4:40:58 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1900 ms
Sep 06, 2012 4:40:58 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Sep 06, 2012 4:40:58 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.29
Sep 06, 2012 4:40:59 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
INFO: Starting ProtocolHandler ["ajp-bio-8009"]
Sep 06, 2012 4:40:59 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 1110 ms
Re: The server configuration is missing or invalided. [message #909356 is a reply to message #909314] Thu, 06 September 2012 22:28 Go to previous message
On 9/6/2012 5:41 PM, howard hardaway wrote:
> Now getting this.
> [snip]
This is a red herring; don't worry about it. If it keeps you up at
night, Google it and you'll see a) that you don't need to worry and why,
plus b) that if you do worry, just getting rid of the warning is a fair
amount of work.
By the way, these are Eclipse web tools (not newcomers') forum questions
you're asking.
Previous Topic:Compiling shallow from Tutorial
Next Topic:Keywords
Current Time: Sun Jul 20 12:25:16 EDT 2025
Powered by FUDForum. Page generated in 0.08394 seconds
