Home » Modeling » EMF » How to merge custom code into generated methods?
How to merge custom code into generated methods? [message #909019] |
Thu, 06 September 2012 08:30  |
I want to let the model code be generated via the normal genmodel code
generation. But, afterwards, I want to add a variable to some classes
and want to add some custom code to already generated methods, such as,
e.g., setMyUnaryFeature(..). This means, before the method is closed
some additional code should be added/merged into it. Can I use JET as it
is done by Ecore itself since I want to merge code and not only to add code?
best regards,
Gilbert
Re: How to merge custom code into generated methods? [message #909061 is a reply to message #909019] |
Thu, 06 September 2012 09:15   |
Hi, Gilbert,
For "one-off" cases where you just need to decorate the generated
method's behaviour with some before and/or after code, it is often
sufficient to rename the generated method with a "Gen" suffix and
replace the original method with your code, delegating to the "Gen"
method at the right place.
For example, if you have
/** @generated */
public void setFoo(Foo newValue) {
you can change this to:
/** @generated */
public void setFooGen(Foo newValue) {
// do something before
setFooGen(newValue);
// do something after
EMF will maintain the *Gen method in subsequent regeneration of the model.
HTH,
Christian
On 2012-09-06 12:30:58 +0000, Gilbert Mirenque said:
> Hello,
> best regards,
> Gilbert
Re: How to merge custom code into generated methods? [message #909091 is a reply to message #909061] |
Thu, 06 September 2012 10:12   |
Hi Christian,
thanks for your reply. I didn't know the *Gen feature. But, since I want
to make the generation I intend available for colleagues and several
metamodels I need to customize the generation process anyway. I don't
want to add setFooGen manually because depending on the structural
features it can be a lot. Is there any possibility to hook into the
default generation?
best regards,
Gilbert
Christian W. Damus wrote:
> Hi, Gilbert,
> /** @generated */
> /** @generated */
> HTH,
> Christian
>> Hello,
>> code?
>> best regards,
>> Gilbert
Re: How to merge custom code into generated methods? [message #909119 is a reply to message #909091] |
Thu, 06 September 2012 11:07   |
Gilbert,
Yes, with dynamic templates (see FAQ) you can modify the templates or
make use of the "<%@ include" points to specify snippets that are
inserted into the standard templates.
On 06/09/2012 4:12 PM, Gilbert Mirenque wrote:
> Hi Christian,
> default generation?
> best regards,
> Gilbert
>> Hi, Gilbert,
>> /** @generated */
>> /** @generated */
>> HTH,
>> Christian
>>> Hello,
>>> code?
>>> best regards,
>>> Gilbert
Re: How to merge custom code into generated methods? [message #909497 is a reply to message #909119] |
Fri, 07 September 2012 04:38   |
Ok, I tried to install JET via Amalgamation but I only get the info that
it is not available anymore. When I look at the category "Modeling" at
http://download.eclipse.org/releases/juno/ it really is not available.
Where to get it?
best regards,
Gilbert
Ed Merks wrote:
> Gilbert,
>> Hi Christian,
>> default generation?
>> best regards,
>> Gilbert
>>> Hi, Gilbert,
>>> /** @generated */
>>> /** @generated */
>>> model.
>>> HTH,
>>> Christian
>>>> Hello,
>>>> as it
>>>> code?
>>>> best regards,
>>>> Gilbert
Re: How to merge custom code into generated methods? [message #909573 is a reply to message #909572] |
Fri, 07 September 2012 06:56   |
Gilbert,
Yes, it will even look for compiled versions of the templates in that
bundle. I'd suggest you start out testing it in the workspace though.
On 07/09/2012 12:53 PM, Gilbert Mirenque wrote:
> Hi Tim,
> thanks for your reply. Is it possible to refer to a plugin URI for the
> "Template Directory"?
> best regards,
> Gilbert
> Tim Schaefer wrote:
>> Hi Gilbert,
>> in your Genmodel you need to set "Dynamic Templates" (under "Templates &
>> Merge") to true and specify the "Template Directory", for example
>> "Projectname/templates". Then in your project, create a directory
>> "templates" and a subdirectory "Class" and put your
>> basicSetGenFeature.override.javajetinc in it.
>> If you generate code now, you should see a project ".JETEmitters"
>> automatically created in your workspace (you may need to remove the
>> default *.resources filter). This way you can see if you have any errors
>> in your template and help you fix it.
>> Regards,
>> Tim
Re: How to merge custom code into generated methods? [message #909582 is a reply to message #909573] |
Fri, 07 September 2012 07:16   |
Thanks Ed. This are good news. Another question: How do I access the
already defined variables (such as genModel) of the base template (such
as Class.javajet)?
best regards,
Gilbert
Ed Merks wrote:
> Gilbert,
>> Hi Tim,
>> best regards,
>> Gilbert
>> Tim Schaefer wrote:
>>> Hi Gilbert,
>>> Regards,
>>> Tim
Re: How to merge custom code into generated methods? [message #909590 is a reply to message #909582] |
Fri, 07 September 2012 07:28   |
Gilbert,
Those snippets are compiled/interpretted in the context of the including
template, so anything in scope at the include point is visible in your
snippet.
> as Class.javajet)?
> best regards,
> Gilbert
> Ed Merks wrote:
>> Gilbert,
>>> Hi Tim,
>>> best regards,
>>> Gilbert
>>> Tim Schaefer wrote:
>>>> Hi Gilbert,
>>>> Regards,
>>>> Tim
Re: How to merge custom code into generated methods? [message #909614 is a reply to message #909590] |
Fri, 07 September 2012 08:22  |
Hi, Gilbert,
You might want to have a look at the templates in the
org.eclipse.uml2.codegen.ecore plug-in from the Eclipse UML2 project.
They are a fairly comprehensive, if somewhat overwhelming, example of
what you need to do.
These templates are injected by an extended generator model, which is
different from dynamic templates, but the mechanism of overriding and
inserting custom templates is the same.
HTH,
Christian
On 2012-09-07 11:28:52 +0000, Ed Merks said:
> Gilbert,
> including template, so anything in scope at the include point is
> visible in your snippet.
>> as Class.javajet)?
>> best regards,
>> Gilbert
>> Ed Merks wrote:
>>> Gilbert,
>>>> Hi Tim,
>>>> best regards,
>>>> Gilbert
>>>> Tim Schaefer wrote:
>>>>> Hi Gilbert,
>>>>> Regards,
>>>>> Tim
Current Time: Sat Jul 19 19:03:05 EDT 2025
Powered by FUDForum. Page generated in 0.34057 seconds
