Home » Modeling » TMF (Xtext) » xtext code-generator
xtext code-generator [message #908400] Wed, 05 September 2012 06:12 Go to next message
I would like to know whether is there a way to check the code generator(Xtend)for the given DSL instance(ie., model) without running it in a new eclipse instance?
Because each and every time when I make changes with the Xtend file(to generate an output which is somewhat template based) I have to run it as a eclipse application to check the generated-output, which sometimes fails if there exists some errors in the generator.
Thanks for any help provided.
Re: xtext code-generator [message #908412 is a reply to message #908400] Wed, 05 September 2012 06:39 Go to previous messageGo to next message
Hi you can configure the generator fragment in the language workflow
to generate a workflow or java main class for the generator
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: xtext code-generator [message #908429 is a reply to message #908412] Wed, 05 September 2012 07:15 Go to previous messageGo to next message
Am 05.09.12 12:39, schrieb Christian Dietrich:
> Hi you can configure the generator fragment in the language workflow to
Or you could write unit tests (strongly recommended).
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Re: xtext code-generator [message #908575 is a reply to message #908400] Wed, 05 September 2012 11:37 Go to previous message
You could write also a MWE2 workflow (which is generated by the generator fragment) and execute this from DEV workspace.
Previous Topic:xtext update sites unavailable?
Next Topic:What to use for automated xtext builds & tests?
Current Time: Sun Jul 20 02:27:17 EDT 2025
Powered by FUDForum. Page generated in 0.03825 seconds
