Tycho build has different runtime behavior as the Run Configuration [message #907984] |
Tue, 04 September 2012 09:56  |
Hey Guys,
i have a curious problem with my e4 tycho build here. A month ago, i've set up a tycho build for our e4 application, which works fine. After this month of developing the product inside eclipse, i've build the product with maven (tycho) again. The build was fine, but the runtime behavior is different.
The product itself has a main plugin with an Application.xmi and a Plugin, which contributes a second Window in a fragment.xmi to the Model at startup (like in Lars Vogel's excellent tutorial: http://www.vogella.com/articles/Eclipse4Modularity/article.html#contributefragments_model).
I've tried to compare the product file (which is relevant for tycho) with the Run Configuration Settings from the Eclipse IDE, without any success. In the Eclipse Build, the second window pops up, in the Tycho Build the EModelService does not find the Second Window. I've created for each Bundle an Activator, in both builds the Bundles start correctly.
Is there a Bundle which i potentially missed in the Tycho product file? (e.g. one which merges the EMF Modelfragment at startup) Or any other suggestions?
greetings Thomas
FUDForum. Page generated in 0.04605 seconds
