Home » Language IDEs » C / C++ IDE (CDT) » Library Paths tab missing??
icon5.gif  Library Paths tab missing?? [message #908139] Tue, 04 September 2012 16:23 Go to next message
Running Eclipse Version: 4.2.0 (Build id: I20120608-1400) with CDT 8.10
In all prior versions of Eclipse + CDT, I've been able to modify libraries and library paths by going to the Project Properties->C++ General->Paths and Symbols and then editing the values in either the libraries or library paths tabs.
In the latest eclipse with CDT, here is what I get (unable to post links due to being a new member, change xx to tt):
hXXp://img849.imageshack.us/img849/8122/screenshotfrom201209041.png
It seems the Library Paths and Libraries tabs are both missing?? How is one to add libraries and library paths to a project without those tabs?
[Updated on: Tue, 04 September 2012 16:23] by Moderator
Re: Library Paths tab missing?? [message #908286 is a reply to message #908139] Wed, 05 September 2012 00:54 Go to previous messageGo to next message
89 views and no answers? Sad
Can anyone confirm if they are seeing the "Library" and "Library Paths" tabs on Juno + CDT 8.1 (Under Project Properties->C++ General->Paths and Symbols)? They are not showing up for me.
[Updated on: Wed, 05 September 2012 00:56] by Moderator
Re: Library Paths tab missing?? [message #909688 is a reply to message #908286] Fri, 07 September 2012 11:31 Go to previous messageGo to next message
Well - that's how it looks on my PC:
Hint: the variable CURLIB I defined in Preferences > C/C++ > Buil > Build variables
https://dl.dropbox.com/u/13412634/Screenshot%20-%2007.09.jpg
[Updated on: Fri, 07 September 2012 11:52] by Moderator
Re: Library Paths tab missing?? [message #909690 is a reply to message #909688] Fri, 07 September 2012 11:35 Go to previous messageGo to next message
Strange - inserting an image by using the icon correspondingly identified obviosely does not work. Hence I try it with a simple link:
-no forget it. I had used a "unsuitable" format of the screenshot-file.
[Updated on: Fri, 07 September 2012 11:48] by Moderator
Re: Library Paths tab missing?? [message #910425 is a reply to message #908139] Sun, 09 September 2012 12:20 Go to previous messageGo to next message
The library and library path tabs are missing in my Juno on OSX 10.6.8. See screen capture.
Re: Library Paths tab missing?? [message #910427 is a reply to message #908286] Sun, 09 September 2012 12:23 Go to previous messageGo to next message
I just submitted a response to the originator of this topic with a screen capture. I am not able to see the Libraries or Library Path tabs in Juno on OSX. Interestingly, they show up on a c++ project that I created with Helios, but when I created a new project, the tabs weren't there.
Re: Library Paths tab missing?? [message #990998 is a reply to message #910427] Sun, 16 December 2012 13:11 Go to previous messageGo to next message
Same problem on OS X with Juno. What is the solution?
Re: Library Paths tab missing?? [message #1001025 is a reply to message #908139] Tue, 15 January 2013 16:51 Go to previous messageGo to next message
I was having this problem and what fixed it for me was right clicking on the projet to get to the properties from the navigator rather than the file menu. Hope this helps someone!
Re: Library Paths tab missing?? [message #1039095 is a reply to message #908139] Thu, 11 April 2013 15:09 Go to previous message
Any idea as to the underlying cause? I'm seeing this too, but opening the properties via the other menu does nothing to help.
--- Carl
Previous Topic:stdout not Displayed with Command Line Arguments
Next Topic:Run control not available
Current Time: Sat Jul 19 10:33:54 EDT 2025
Powered by FUDForum. Page generated in 0.05047 seconds
