Home » Modeling » UML2 » PrimitiveType
PrimitiveType [message #907997] Tue, 04 September 2012 10:20 Go to next message
Hi I want to create a new property inside a class which has the type Integer. I use this construct: modelClass.createOwnedAttribute(String arg0, Type arg1, EClass arg2).
Can anyone post an example how to create a property with this construct I cant resolve type.
regards
Florian
Re: PrimitiveType [message #908170 is a reply to message #907997] Tue, 04 September 2012 17:33 Go to previous messageGo to next message
> regards
> Florian
Have you looked at the Getting started with UML2 tutorial?
Ed Willink
Re: PrimitiveType [message #908239 is a reply to message #907997] Tue, 04 September 2012 21:59 Go to previous messageGo to next message
Of course I did apparently it does not say anything about the Integer primitive type. As asked before in another topic I have some difficulties in finding out how to resolve some expected arguments as Type for example.
Re: PrimitiveType [message #908283 is a reply to message #908239] Wed, 05 September 2012 00:49 Go to previous messageGo to next message
Since you're earlier reply was
"Works like a charm thank you so much!!! "
I assumed that you now understood how to call UML Java functions. The
getting started tutorial has an example of createOwnedAttribute so I'm
unclear what your problem is.
Try posting your best attempt.
Ed Willink
> Type for example.
Re: PrimitiveType [message #908568 is a reply to message #908283] Wed, 05 September 2012 11:20 Go to previous messageGo to next message
Property duration = modelClass.createOwnedAttribute("duration", modelClass.getPackage().getOwnedType("int"), UMLPackage.Literals.PROPERTY);
This creates the property but without a Type I do not now how to resolve it properly as stated before.
regards
Florian
Re: PrimitiveType [message #908574 is a reply to message #908568] Wed, 05 September 2012 11:32 Go to previous messageGo to next message
Does your modelClass.getPackage() have an "int" type?
If not perhaps you want to "Integer" from the UML Types package.
Ed Willink
> regards
> Florian
Re: PrimitiveType [message #908621 is a reply to message #908574] Wed, 05 September 2012 13:03 Go to previous messageGo to next message
"Integer" does not change anything still no Type Sad
Re: PrimitiveType [message #908625 is a reply to message #908621] Wed, 05 September 2012 13:07 Go to previous messageGo to next message
I cannot help you if you do not provide a problem that is reproducible
or comments that are meaningful.
Ed Willink
On 05/09/2012 18:03, Florian Wartenberg wrote:
> "Integer" does not change anything still no Type :(
Re: PrimitiveType [message #908642 is a reply to message #908625] Wed, 05 September 2012 14:05 Go to previous messageGo to next message
Ok I have a .uml file which I load then I do some transformations on the model. At some point I have to create a new property inside my main class. Therefore I use the line written above. My property is created but has no type. I want to have a property which has the type "<PrimitveType> Integer" which several other properties of the model already have. The second argument of the method is "Type" I do not know what Java or EMF is expecting me to resolve it to so I get the Integer type. If I for example resolve the second argument to my class ("modelClass") then the property is created whith a type and the type is <Class> ECU which is the name of my class inside the model.
regards Florian
Re: PrimitiveType [message #908697 is a reply to message #908642] Wed, 05 September 2012 16:42 Go to previous messageGo to next message
Precisely. You have a UML file. I have nothing I can reproduce. I wish
you luck with your problem.
Ed Willink
> regards Florian
Re: PrimitiveType [message #908767 is a reply to message #908642] Wed, 05 September 2012 21:01 Go to previous message
Hi, Florian,
If you have other classes in your model that have properties that
reference Integer as their type, then where did they get it from?
Probably it is the Integer in the UML Primitive Types library. The URI
for the library resource is
pathmap://UML_LIBRARIES/UMLPrimitiveTypes.profile.uml
You would see it already loaded in the editor if you open your model in
the UML Editor.
Anyways, given that you already have properties of Integer type, you
should be able to find the library resource (URI as above) loaded in
your resource set. The first element in the resource is a package on
which you can use the getOwnedType(…) method that you mentioned
earlier, to get the Integer type.
HTH,
Christian
> regards Florian
Previous Topic:TimeObservation for transitions
Next Topic:ApplyStereotypes takes seconds at first time
Current Time: Sun Jul 20 04:17:04 EDT 2025
Powered by FUDForum. Page generated in 1.05117 seconds
