Home » Modeling » GMF (Graphical Modeling Framework) » Change model on property change
Change model on property change [message #895034] Wed, 11 July 2012 09:24 Go to next message
I want to change the model if a property changes. For example I have the domain element "AnalysisFunctionPrototype" and I want to add an element to the element if one if its propertys is changed.
So far I can register if the desired property has changed via "handleNotificationEvent(..)" in my AnalysisFunctionPrototypeCanonicalEditPolicy.
But I don't know how to get the domain element, e.g. I don't know how to do
AnalysisFunctionPrototype type = get????
type.getList().add(new ...)
Btw, I don't want to edit the generated EMF code, instead I want to adjust th generated diagram code.
Re: Change model on property change [message #895051 is a reply to message #895034] Wed, 11 July 2012 10:34 Go to previous messageGo to next message
Matthias,
you may try
AnalysisFunctionPrototype type = (AnalysisFunctionPrototype)
getSemanticHost();
Manuel
Re: Change model on property change [message #896130 is a reply to message #895051] Tue, 17 July 2012 07:07 Go to previous messageGo to next message
if you are using the latest version of GMF-Tooling, you should take a look to https://bugs.eclipse.org/bugs/show_bug.cgi?id=368398
Re: Change model on property change [message #896183 is a reply to message #896130] Tue, 17 July 2012 10:04 Go to previous messageGo to next message
Hi Aurelien,
I use the latest information of GMF but cannot find the visual pin model element in GMFGraph. Can you give a hint on where to add it to? The Visual Effect Mapping in gmfmap is available.
Ralph
Re: Change model on property change [message #907444 is a reply to message #896130] Mon, 03 September 2012 22:39 Go to previous messageGo to next message
how to define a PIN?
Re: Change model on property change [message #907522 is a reply to message #907444] Tue, 04 September 2012 02:55 Go to previous messageGo to next message
in the gmfgraph model you should be able to add a pin such as color pin or visible pin to the figure you want to change dynamically. Make sure that you have installed GMF 3.0.
Ralph
Re: Change model on property change [message #907588 is a reply to message #907444] Tue, 04 September 2012 04:02 Go to previous messageGo to next message
I am using Helios service release 1....i trying to install GMF 3.0 but this version is not available. can u please give a link to download??
Re: Change model on property change [message #907606 is a reply to message #907444] Tue, 04 September 2012 04:03 Go to previous messageGo to next message
Re: Change model on property change [message #907607 is a reply to message #907444] Tue, 04 September 2012 04:11 Go to previous messageGo to next message
I cannot find GMF version 3.0. can u give me any link where i can download?
Re: Change model on property change [message #907614 is a reply to message #907444] Tue, 04 September 2012 04:03 Go to previous messageGo to next message
Re: Change model on property change [message #907622 is a reply to message #907444] Tue, 04 September 2012 04:03 Go to previous messageGo to next message
Re: Change model on property change [message #907623 is a reply to message #907444] Tue, 04 September 2012 04:11 Go to previous messageGo to next message
Re: Change model on property change [message #907627 is a reply to message #907444] Tue, 04 September 2012 04:03 Go to previous messageGo to next message
Re: Change model on property change [message #907628 is a reply to message #907444] Tue, 04 September 2012 04:11 Go to previous messageGo to next message
Re: Change model on property change [message #907640 is a reply to message #907444] Tue, 04 September 2012 04:03 Go to previous messageGo to next message
Re: Change model on property change [message #907641 is a reply to message #907444] Tue, 04 September 2012 04:11 Go to previous messageGo to next message
Re: Change model on property change [message #907650 is a reply to message #907444] Tue, 04 September 2012 04:03 Go to previous messageGo to next message
Re: Change model on property change [message #907651 is a reply to message #907444] Tue, 04 September 2012 04:11 Go to previous messageGo to next message
Re: Change model on property change [message #907660 is a reply to message #907444] Tue, 04 September 2012 04:03 Go to previous messageGo to next message
Re: Change model on property change [message #907661 is a reply to message #907444] Tue, 04 September 2012 04:11 Go to previous messageGo to next message
Re: Change model on property change [message #907675 is a reply to message #907444] Tue, 04 September 2012 04:03 Go to previous messageGo to next message
Re: Change model on property change [message #907676 is a reply to message #907444] Tue, 04 September 2012 04:11 Go to previous messageGo to next message
Re: Change model on property change [message #907689 is a reply to message #907444] Tue, 04 September 2012 04:03 Go to previous messageGo to next message
Re: Change model on property change [message #907690 is a reply to message #907444] Tue, 04 September 2012 04:11 Go to previous messageGo to next message
Re: Change model on property change [message #907708 is a reply to message #907444] Tue, 04 September 2012 04:03 Go to previous messageGo to next message
Re: Change model on property change [message #907709 is a reply to message #907444] Tue, 04 September 2012 04:11 Go to previous messageGo to next message
Re: Change model on property change [message #907732 is a reply to message #907444] Tue, 04 September 2012 04:11 Go to previous messageGo to next message
Re: Change model on property change [message #908042 is a reply to message #907732] Tue, 04 September 2012 11:35 Go to previous messageGo to next message
you can get it via the Juno release update site.
Ralph
Re: Change model on property change [message #908240 is a reply to message #908042] Tue, 04 September 2012 21:59 Go to previous message
yes i convert my project to juno and install gmf 3.0. can u tell me more about PINs??
Previous Topic:separate property box while double clicking the node
Next Topic:How to delete Views/GraphicalEditParts from diagram programmatically?
Current Time: Sat Jul 19 16:39:59 EDT 2025
Powered by FUDForum. Page generated in 0.10997 seconds
