NullPointerException when exiting my sample GMF editor [message #903630] |
Fri, 24 August 2012 11:13  |
I observed the following problem after upgrading to Juno and GMF 3.0.
I define a very simple model (only two elements with a containment relation) and generate the corresponding GMF editor.
I launch the editor and create a sample diagram file.
Then I add an element to the diagram.
No matter, I save or not the diagram, I then get a NullPointerException when exiting the editor.
Can anyone help me figure out what's wrong (see the stacktrace hereafter) ?
If I choose to save the diagram before exiting, it's done.
Laurent
!ENTRY org.eclipse.core.commands 4 2 2012-08-24 16:58:24.767
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.commands".
!STACK 0
at org.eclipse.emf.transaction.impl.TransactionImpl.start(TransactionImpl.java:257)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.startTransaction(TransactionalEditingDomainImpl.java:424)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:321)
at org.eclipse.gmf.runtime.diagram.ui.internal.actions.PropertyChangeAction.getPropertyValue(PropertyChangeAction.java:148)
at org.eclipse.gmf.runtime.diagram.ui.internal.actions.PropertyChangeAction.getOperationSetPropertyValue(PropertyChangeAction.java:132)
at org.eclipse.gmf.runtime.diagram.ui.actions.BooleanPropertyAction.getNewPropertyValue(BooleanPropertyAction.java:46)
at org.eclipse.gmf.runtime.diagram.ui.internal.actions.PropertyChangeAction.updateTargetRequest(PropertyChangeAction.java:116)
at org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.refresh(DiagramAction.java:113)
at org.eclipse.gmf.runtime.diagram.ui.actions.CheckedPropertyAction.refresh(CheckedPropertyAction.java:64)
at org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler.historyNotification(AbstractActionHandler.java:602)
at org.eclipse.core.commands.operations.DefaultOperationHistory$2.run(DefaultOperationHistory.java:941)
at org.eclipse.core.commands.operations.DefaultOperationHistory.notifyListeners(DefaultOperationHistory.java:930)
at org.eclipse.core.commands.operations.DefaultOperationHistory.notifyRemoved(DefaultOperationHistory.java:1054)
at org.eclipse.core.commands.operations.DefaultOperationHistory.internalRemove(DefaultOperationHistory.java:902)
at org.eclipse.core.commands.operations.DefaultOperationHistory.flushUndo(DefaultOperationHistory.java:631)
at org.eclipse.core.commands.operations.DefaultOperationHistory.dispose(DefaultOperationHistory.java:330)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.stopListening(DiagramEditor.java:1014)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFlyOutPalette.stopListening(DiagramEditorWithFlyOutPalette.java:617)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.dispose(DiagramEditor.java:677)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.dispose(DiagramDocumentEditor.java:212)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:209)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:374)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:837)
at org.eclipse.e4.core.internal.di.InjectorImpl.uninject(InjectorImpl.java:170)
at org.eclipse.e4.core.internal.di.Requestor.uninject(Requestor.java:129)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:71)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:106)
at org.eclipse.e4.core.internal.contexts.EclipseContext.removeListenersTo(EclipseContext.java:427)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.uninject(ContextInjectionFactory.java:143)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:849)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:768)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:763)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:748)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:801)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.disposeWidget(ElementReferenceRenderer.java:122)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:840)
at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1506)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:1158)
at org.eclipse.ui.internal.WorkbenchWindow.access$16(WorkbenchWindow.java:1135)
at org.eclipse.ui.internal.WorkbenchWindow$10.run(WorkbenchWindow.java:1184)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1182)
at org.eclipse.ui.internal.Workbench$16.run(Workbench.java:1103)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1086)
at org.eclipse.ui.internal.Workbench.access$16(Workbench.java:998)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1179)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1177)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1150)
at org.eclipse.ui.internal.handlers.QuitHandler.execute(QuitHandler.java:36)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:492)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.05015 seconds
