Home » Language IDEs » C / C++ IDE (CDT) » symbols not resolving in eclipse, but resolving on command line
symbols not resolving in eclipse, but resolving on command line [message #906830] Sun, 02 September 2012 13:55 Go to next message
Eclipse : Juno
OS: Fedora Linux 17
I have a whole c++ project setup and compiling on the command line (gcc 4.7) and from within emacs, producing object files and an executable.
I wanted to use eclipse for the project and imported this existing makefile project in. All was ok.
However, when I opened one of the source files in the eclipse editor, I now get a bunch of errors for shared_ptr not being resolved at
using <memory>
using std::shared_ptr;
I have had std=c++0x as a make flag and including <memory>
This doesnt make sense since the project did compile in eclipse when I first imported the project. This happened when I open the file with shared_ptr in the editor ???
Please note that my entire project works when compiling from the command line. (And runs afterwards Smile
tia,
Sunil
Re: symbols not resolving in eclipse, but resolving on command line [message #907028 is a reply to message #906830] Mon, 03 September 2012 03:14 Go to previous messageGo to next message
These are messages from the internal code analyzer. You're index is not setup correctly.
See http://wiki.eclipse.org/CDT/User/FAQ#CDT_does_not_recognize_C.2B.2B11_features
point "Source navigation and symbol resolving"
Re: symbols not resolving in eclipse, but resolving on command line [message #907291 is a reply to message #907028] Mon, 03 September 2012 13:18 Go to previous message
I looked at the directions on this page provided, however, I dont see any option labeled "compiler invocation arguments" in discovery options.
(ps. I have all the correct flags in the makefiles - the project has been building using the existing makefile for some time now. I wanted to see if I could use the ide for development).
Is the faq outdated as far as the proper way to setup discovery options ?
Previous Topic:GDB Hardware Debugging
Next Topic:Automate addition of symbols , includes, source filters for new projects
Current Time: Sat Jul 19 11:21:54 EDT 2025
Powered by FUDForum. Page generated in 0.04432 seconds
