Home » Archived » M2M (model-to-model transformation) » [ATL] Ant task problem: "am3.loadModel"
[ATL] Ant task problem: "am3.loadModel" [message #90710] Mon, 29 September 2008 11:07 Go to next message
Hello there,
I'm new to the ATL language, and after a brief tutorial provided by the
INRIA team, i tried to run the ATL transformation 'UML2OWL' downloaded
from the ATL zoo.
But, i get an error when i run the build.xml Ant file:
"[...]\workspace\UML2OWL\build.xml:33: Problem: failed to create task or
type am3.loadModel"
I built the am3 plugins (version 0.4.0) from the SVN repository (not the
deprecated ones), but nothing changed. I also configured all the things
for my Ant file to be launched in the same JRE as my workspace, and for my
workspace to be refreshed each time i launch the Ant file.
Then, i even built the deprecated plugin
'org.eclipse.gmt.am3.tools.ant_0.2.0.200809261429.jar' from the SVN
repository, without success.
I must have forgotten something, so thanks for any help to make it work !
Adrien.
Re: [ATL] Ant task problem: "am3.loadModel" [message #90728 is a reply to message #90710] Tue, 30 September 2008 03:45 Go to previous messageGo to next message
Sorry, i forgot to mention that i'm running under Eclipse Modeling Tools
v3.4.1 (Eclipse + EMF, GMF, MDT XSD/OCL/UML2, M2M, M2T, and EMFT
elements), up-to-date with ATL v2.0.1.
Re: [ATL] Ant task problem: "am3.loadModel" [message #90758 is a reply to message #90710] Tue, 30 September 2008 09:45 Go to previous messageGo to next message
What happens if you try to run with the "Run in the same JRE as workspace"
option on in the launch confguration?
Alfons
"Adrien Debosschere" <adrien.debosschere@gmail.com> schreef in bericht
news:d96546363990efcedb8f0232e8f4b2e3$1@www.eclipse.org...
> Hello there,
> from the ATL zoo.
> type am3.loadModel"
> Regards,
> Adrien.
Re: [ATL] Ant task problem: "am3.loadModel" [message #90819 is a reply to message #90758] Wed, 01 October 2008 03:47 Go to previous messageGo to next message
Thanks for your reply !
I've already changed the "launch configuration" of my Ant file, to make it
run into the same JRE as my workspace, but i got the same error anyway.
Btw, i have the v2.0.1 of the org.eclipse.m2m.atl.* plugins. I'll try to
update these using CVS, and i'll keep you posted.
Adrien
Re: [ATL] Ant task problem: "am3.loadModel" [message #91159 is a reply to message #90819] Fri, 03 October 2008 05:11 Go to previous message
Even with the last version of ATL (v2.1.0), i can't use AM3 tasks in my
Ant file...
After days of hacking my Eclipse plugins, i think i will delete all my
stuff and make a clean install.
Previous Topic:[ATL] Can I use a model library in ATL transformation
Next Topic:[QVTO] Parser error using enumeration
Current Time: Sat Jul 19 11:24:25 EDT 2025
Powered by FUDForum. Page generated in 0.26279 seconds
