Home » Archived » BIRT » can we connect BIRT with any community forum and create the reports
can we connect BIRT with any community forum and create the reports [message #905828] Fri, 31 August 2012 02:49 Go to next message
In my company we have a community. So can i connect BIRT Report Designer with that community and create the reports from the information present in the community. Please suggest some solution.
Re: can we connect BIRT with any community forum and create the reports [message #906186 is a reply to message #905828] Fri, 31 August 2012 16:00 Go to previous messageGo to next message
Where is the information stored? Do you have an API or URL to connect
and retrieve data? If so the answer is yes.
Jason
On 8/31/2012 2:49 AM, Sameer Singh wrote:
> Hi
Re: can we connect BIRT with any community forum and create the reports [message #906707 is a reply to message #906186] Sun, 02 September 2012 05:34 Go to previous messageGo to next message
Jason
I want to know which API or URL will use to connect with Community. Information stored as a list in the community.
Re: can we connect BIRT with any community forum and create the reports [message #907012 is a reply to message #906186] Mon, 03 September 2012 02:32 Go to previous messageGo to next message
Jason
Information stored in the community is a sharepoint list.
Re: can we connect BIRT with any community forum and create the reports [message #908015 is a reply to message #907012] Tue, 04 September 2012 10:47 Go to previous messageGo to next message
Sameer
I have not tried this but if you can access a sharepoint list from Java,
like:
http://davidsit.wordpress.com/2010/02/10/reading-a-sharepoint-list-with-java-tutorial/
You should be able to call those same Java Classes from BIRT using a
Scripted Data Source. If the share point list can be accessed using a
Web Service you could also use the BIRT Web Service data source.
Jason
On 9/3/2012 2:32 AM, Sameer Singh wrote:
> Jason
Re: can we connect BIRT with any community forum and create the reports [message #909428 is a reply to message #908015] Fri, 07 September 2012 02:03 Go to previous messageGo to next message
Jason
I tried with to create data source using web service data sources. When i am testing the connection it is showing "ping succeded". But when i am creating data set i am getting this error " WSDLException: faultCode=PARSER_ERROR: Problem parsing 'site_name'.: The prefix "ie" for element "ie:menuitem" is not bound."
Re: can we connect BIRT with any community forum and create the reports [message #909716 is a reply to message #909428] Fri, 07 September 2012 12:30 Go to previous messageGo to next message
Is the web service publicly available? If so can you post it?
Jason
Re: can we connect BIRT with any community forum and create the reports [message #910652 is a reply to message #909716] Mon, 10 September 2012 02:51 Go to previous messageGo to next message
Jason
No it's not a public web service. You can't access the site.
Re: can we connect BIRT with any community forum and create the reports [message #910956 is a reply to message #910652] Mon, 10 September 2012 13:43 Go to previous message
It will be difficult to determine what is wrong without being able to run it. Can you try the example in this dev share entry?
http://www.birt-exchange.org/org/devshare/designing-birt-reports/175-birt-web-services-example/
Jason
Previous Topic:Bug? Tooltip still shows up when series is invisible
Next Topic:The output format of
Current Time: Sat Jul 19 20:05:26 EDT 2025
Powered by FUDForum. Page generated in 0.25426 seconds
