JUNO j2ee ide is not starting. [message #904854] |
Wed, 29 August 2012 05:27  |
Unzipped the juno x86 zip in my windows xp sp3 32 bit machine. It is not starting and it is giving the following error: NOTE: that the reported file is there in the given directory...
!SESSION 2012-08-29 13:06:49.933 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.6.0_29
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.osgi 4 0 2012-08-29 13:07:01.888
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
C:\store\work\tools\eclipse-jee-juno-win32\eclipse\configuration\org.eclipse.osgi\bundles\629\2\.cp\swt-win32-4233.dll: Error performing inpage operation
no swt-win32 in java.library.path
C:\Documents and Settings\XYZ\.swt\lib\win32\x86\swt-win32-4233.dll: Error performing inpage operation
Can't load library: C:\Documents and Settings\XYZ\.swt\lib\win32\x86\swt-win32.dll
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:331)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:240)
at org.eclipse.swt.internal.C.<clinit>(C.java:21)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:138)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:650)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
at org.eclipse.ui.internal.ide.application.IDEApplication.createDisplay(IDEApplication.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:96)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.04157 seconds
