Cross Tab export to dataSet [message #903625] |
Fri, 24 August 2012 11:10  |
I've some problems with the calculation in the cross tab.
1. I need to calculate a difference between deux types de colonnes.
2. I need also to calculate a difference between deux lignes.
For example,
OK | KO
Jan N1_OK | N1_KO
Fev N2_OK | N2_KO
I want to calcul the difference between the number of OK et KO (For example N1_OK-N1_KO)
I want to calul the difference avec the month above. (For example N2_KO-N1_KO)
I don't find how to do it with the option "Add derive mesure". If it's possible, can someone help me?
Is it possible to export the result of the cross tab in a dataSet which i can do many types the calcul and configure the presentation of my table more simplely?
Thank you in advance
FUDForum. Page generated in 0.06144 seconds
