Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » problem with initialzing jpoxDataStore(emf+teneo+derby)
problem with initialzing jpoxDataStore(emf+teneo+derby) [message #90377] |
Wed, 18 July 2007 06:53  |
Originally posted by: danceslower.sina.com
Hi all,
I am trying to integrate emf,teneo and derby into one application.
However, a strange problem occured when i tried to configue the database
connection.Here is the code:
Properties properties = new Properties();
properties.setProperty(PersistenceConfiguration.JDO_DATASTOR E_DRIVERNAME_PROPERTY,
"com.ibm.db2.jcc.DB2Driver");
properties.setProperty(PersistenceConfiguration.JDO_DATASTOR E_URL_PROPERTY,
"jdbc:derby:net://localhost:1527/MyDbTest");
properties.setProperty(PersistenceConfiguration.JDO_DATASTOR E_USERNAME_PROPERTY,
"sa");
properties.setProperty(PersistenceConfiguration.JDO_DATASTOR E_PASSWORD_PROPERTY,
"sa");
properties.setProperty(PersistenceConfiguration.AUTO_CREATE_ TABLES_PROPERTY, "true");
properties.setProperty(PersistenceConfiguration.CACHE_LEVEL_ 1_TYPE_PROPERTY,
"org.eclipse.emf.teneo.jpox.cache.EMFWeakRefCache");
// create/register the JpoxDataStore, set the db props and the epackages
to persist, initialize creates
// the database
String pmfName = "MyPMF"; // the name of the JpoxDataStore
JpoxDataStore jpoxDataStore =
JpoxHelper.INSTANCE.createRegisterDataStore(pmfName);
jpoxDataStore.setProperties(properties);
jpoxDataStore.setEPackages(new EPackage[] { CustomerPackage.eINSTANCE });
jpoxDataStore.initialize();
an exception was throwed when execute to "jpoxDataStore.initialize". and
here is the error information:
log4j:WARN No appenders could be found for logger
(org.eclipse.emf.teneo.jpox.JpoxHelper).
log4j:WARN Please initialize the log4j system properly.
Exception in thread "main" javax.jdo.JDOFatalUserException: Level 1 Cache
"org.eclipse.emf.teneo.jpox.cache.EMFWeakRefCache" is not registered. Please
check your CLASSPATH and specification.
at
org.jpox.jdo.JPOXJDOHelper.getJDOExceptionForJPOXException(J POXJDOHelper.java:320)
at
org.jpox.AbstractPersistenceManagerFactory.freezeConfigurati on(AbstractPersistenceManagerFactory.java:133)
at
org.jpox.PersistenceManagerFactoryImpl.getPersistenceManager Factory(PersistenceManagerFactoryImpl.java:120)
at javax.jdo.JDOHelper.getPersistenceManagerFactory(JDOHelper.j ava:710)
at javax.jdo.JDOHelper.getPersistenceManagerFactory(JDOHelper.j ava:633)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.createSchema(JpoxDa taStore.java:513)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.initialize(JpoxData Store.java:213)
at com.test.customer.impl.TestTeneoCustomer.main(TestTeneoCusto mer.java:69)
NestedThrowablesStackTrace:
Level 1 Cache "org.eclipse.emf.teneo.jpox.cache.EMFWeakRefCache" is not
registered. Please check your CLASSPATH and specification.
org.jpox.exceptions.JPOXUserException: Level 1 Cache
at
org.jpox.ObjectManagerImpl.initialiseLevel1Cache(ObjectManag erImpl.java:271)
at org.jpox.ObjectManagerImpl.<init>(ObjectManagerImpl.java:245)
at
org.jpox.AbstractPersistenceManager.<init>(AbstractPersistenceManager.java:113)
at org.jpox.PersistenceManagerImpl.<init>(PersistenceManagerImpl.java:39)
at
org.jpox.PersistenceManagerFactoryImpl.getPersistenceManager (PersistenceManagerFactoryImpl.java:256)
at
org.jpox.PersistenceManagerFactoryImpl.getPersistenceManager (PersistenceManagerFactoryImpl.java:236)
at org.jpox.store.rdbms.SchemaAutoStarter.open(SchemaAutoStarte r.java:136)
at org.jpox.store.StoreManager.initialiseAutoStart(StoreManager .java:298)
at
org.jpox.store.rdbms.RDBMSManager.initialiseSchema(RDBMSMana ger.java:758)
at org.jpox.store.rdbms.RDBMSManager.<init>(RDBMSManager.java:306)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.jpox.util.ClassUtils.newInstance(ClassUtils.java:93)
at
org.jpox.store.StoreManagerFactory.getStoreManager(StoreMana gerFactory.java:58)
at
org.jpox.ObjectManagerFactoryImpl.initialiseStoreManager(Obj ectManagerFactoryImpl.java:168)
at
org.jpox.AbstractPersistenceManagerFactory.freezeConfigurati on(AbstractPersistenceManagerFactory.java:119)
at
at
at
I have added the "org.eclipse.emf.teneo.jpox.jar" into plugins as while as
java build path of this project, why such exception has been reported? The
help document in the eclipse.org also shows that its crucial to set this
cache property and it should be added in this manner.
where is the problem?
Hoping for response!
Thank you very much!
Re: problem with initialzing jpoxDataStore(emf+teneo+derby) [message #90395 is a reply to message #90377] |
Wed, 18 July 2007 07:18  |
Hi Wangyan,
Are you maybe using jpox 1.2? Teneo is at jpox 1.1.8. For jpox 1.2 you need to add a plugin.xml
defining the teneo cache definitions. See here for the jpox documentation:
http://www.jpox.org/docs/1_2/extensions/level1_cache.html
Note that the Teneo cache is only required to ensure that eContainer pointers are correct, if you
are not interested in the correct value of the eContainer member then this cache is not required.
gr. Martin
wangyan wrote:
> Hi all,
> "sa");
> "sa");
> // the database
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: problem with initialzing jpoxDataStore(emf+teneo+derby) [message #608787 is a reply to message #90377] |
Hi Wangyan,
gr. Martin
wangyan wrote:
> Hi all,
> "sa");
> "sa");
> // the database
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
The Netherlands
Current Time: Sat Jul 19 09:39:53 EDT 2025
Powered by FUDForum. Page generated in 0.03343 seconds
