Home » Modeling » TMF (Xtext) » How to generate a field with a generic type
How to generate a field with a generic type [message #903769] Sat, 25 August 2012 13:49 Go to next message
I'm using the following code to generate a field:
val mapType = entity.newTypeRef(typeof(Map))
members += entity.toField("columnValues", mapType) [
	setInitializer [
		append('''new HashMap<«entity.name»,String>()''')
That gives me:
 private Map<?,?> columnValues = new HashMap<Customer,String>();
But I would like to have:
 private Map<Customer,String> columnValues = new HashMap<Customer,String>();
And I would like to generate the import statement for the HashMap.
Is this possible ?
Roger
Re: How to generate a field with a generic type [message #903772 is a reply to message #903769] Sat, 25 August 2012 14:52 Go to previous messageGo to next message
what about
val mapType = entity.newTypeRef(typeof(Map), newTypeRef, entity.newTypeRef(typeof(String)))
~Christian
Re: How to generate a field with a generic type [message #903775 is a reply to message #903772] Sat, 25 August 2012 15:35 Go to previous messageGo to next message
thanks a lot. The generic type is generated but how do I generate the import ?
Roger
Re: How to generate a field with a generic type [message #903781 is a reply to message #903775] Sat, 25 August 2012 17:26 Go to previous messageGo to next message
setInitializer [
		append('''new java.util.HashMap<«entity.name»,String>()''')
or
setInitializer [
		imports.add("java.util.HashMap")
Re: How to generate a field with a generic type [message #903837 is a reply to message #903781] Sun, 26 August 2012 02:46 Go to previous messageGo to next message
The import statement is ignored. At least in the 2.3.1 version I'm using here.
setInitializer [
Roger
Re: How to generate a field with a generic type [message #903840 is a reply to message #903837] Sun, 26 August 2012 04:05 Go to previous message
setInitializer [
		append("new ").append(entity.newTypeRef(typeof(HashMap)).type)
		.append('''<«entity.name»,String>()''')
Previous Topic:New Project Wizard without use XtextNewProjectWizard ?
Next Topic:Books on Xtext
Current Time: Sat Jul 19 22:28:59 EDT 2025
Powered by FUDForum. Page generated in 0.03935 seconds
