Home » Language IDEs » C / C++ IDE (CDT) » [SOLVED] Debugging not working while running works
[SOLVED] Debugging not working while running works [message #903401] Thu, 23 August 2012 09:42 Go to next message
I've been having problems debugging my code in Eclipse. For some reason debugging does not work. Building an executable works fine. I can run it in terminal but when I want to debug, it crashes. Here is my simple code.
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
int main(void)
  static const char filename[] = "test.txt";
  FILE *file = fopen ( filename, "r" );
  if ( file != NULL )
    char line [ 128 ];
    while ( fgets ( line, sizeof line, file ) != NULL )
      fputs ( line, stdout );
    fclose ( file );
  else
    perror ( filename );
  return 0;
The debugger runs until fopen and than it crashes and says:
Can't find a source file at "../sysdeps/wordsize-64/../../libio/iofopen.c"
Locate the file or edit the source lookup path to include its location.
This while normally running the code (ctrl+F11) does give the desired result. Also running the executable in terminal gives the desired result. Anyone have ideas?
[Updated on: Thu, 30 August 2012 08:58] by Moderator
Re: Debugging not working while running works [message #903532 is a reply to message #903401] Fri, 24 August 2012 03:50 Go to previous messageGo to next message
Seems like every operation done using some form of library use crashes the debugging routine. I can make arrays, manipulate them and do whatever. Making use of fopen or sprint or whatever crashes the debugging. While I can still compile and run. So right now my only means of debugging is sprintf while running the complete program...
Re: Debugging not working while running works [message #903551 is a reply to message #903532] Fri, 24 August 2012 05:16 Go to previous message
Aah! I made the ultimate n00b mistake. In debugging I used step into in stead of step over. Fastkeys were mixed up and a long day made it difficult to recognize my mistake.
Previous Topic:[Solved] Cross-project #include error
Next Topic:Configuring the debugger so as to step over when stepping over
Current Time: Sat Jul 19 10:37:22 EDT 2025
Powered by FUDForum. Page generated in 0.05495 seconds
