Home » Eclipse Projects » Remote Application Platform (RAP) » CKeditor
CKeditor [message #896062] Tue, 17 July 2012 02:48 Go to next message
I´m using RAP Standalone with version 1.5.
I have developed a program that saves scripts in a Mysql database.
I write the Scripts in a CKEditor and then i click a button(save).
My question is: how do I get the text from the text area?
I have tried the:
getText();
setText();
getData();
Method, but that doesnt work.
see File Attachments
[Updated on: Tue, 17 July 2012 03:22] by Moderator
Re: CKeditor [message #896101 is a reply to message #896062] Tue, 17 July 2012 05:22 Go to previous messageGo to next message
Hi.
This might happen if you use JEE mode, which i guess you do. (If you
already use SWT compatibility this is another issue than i think it is.)
Either use SWT compatibility mode, or wait 'till i fix this (sometime in
the coming weeks). The fix will involve a callback mechanism instead of
a getText method.
IF you are interested in the hows and whys:
SWT vs. JEE mode:
http://eclipse.org/rap/developers-guide/devguide.php?topic=advanced/application-setup.html#compat
The issue with JEE and browser widget:
http://eclipse.org/rap/developers-guide/devguide.php?topic=rwt/differences.html#browser
Greetings,
Tim
Am 17.07.2012 08:48, schrieb Alexander Knieper:
> Hello,
> My question is: how do I get the text from the text area? I have tried
> the:
> getText();
> setText();
> getData();
Tim Buschtöns
Twitter: @EclipseRAP
Re: CKeditor [message #896336 is a reply to message #896101] Wed, 18 July 2012 02:31 Go to previous messageGo to next message
How can i use/start the SWT compatibility mode?
Re: CKeditor [message #896351 is a reply to message #896336] Wed, 18 July 2012 03:12 Go to previous messageGo to next message
Alexander Knieper wrote on Wed, 18 July 2012 02:31
I have set the swt mode with the Method
application.setOperationMode(OperationMode.SWT_COMPATIBILITY);
before the entrypoint.
When i started the programm the popup (the methods in JEE Mode doesnt exist) doesnt come.
But now the buttons doesnt work!
Re: CKeditor [message #896352 is a reply to message #896351] Wed, 18 July 2012 03:25 Go to previous messageGo to next message
In SWT mode, your entrypoint needs an SWT mainloop:
while( !shell.isDisposed() ) {
if( !display.readAndDispatch() ) {
display.sleep();
display.dispose();
Regards, Ralf
Ralf Sternberg
Re: CKeditor [message #896425 is a reply to message #896352] Wed, 18 July 2012 07:36 Go to previous messageGo to next message
Thanks for your help.
It works Smile
Re: CKeditor [message #903120 is a reply to message #896101] Wed, 22 August 2012 02:35 Go to previous messageGo to next message
Tim Buschtoens wrote on Tue, 17 July 2012 05:22
Hi.
a getText method.
Is the fix which involve a callback mechanism instead of a getText Method published?
Re: CKeditor [message #903341 is a reply to message #903120] Thu, 23 August 2012 04:48 Go to previous message
Hi!
> Method published?
Yes, it's in the "JEE" branch. We didn't advertise it much because it's
not really an ideal solution. We recommend to use the widget with the
SWT compatibility mode if possible.
Greetings,
Tim
Tim Buschtöns
Previous Topic:Logout
Next Topic:Problem to proxy RAP-Runtime in Nexus
Current Time: Sat Jul 19 09:42:35 EDT 2025
Powered by FUDForum. Page generated in 0.04346 seconds
