Home » Proposals » OSGi Enterprise Tools » How to Export Dependent Plugins in Eclipse(how to export dependent plugins form eclipse)
How to Export Dependent Plugins in Eclipse [message #903321] Thu, 23 August 2012 03:27 Go to next message
Hello All,
I am working with two Eclipses plug-in. One in core and 2nd is UI plug-in. I have used extension-points and extensions to communicate between two plug-in. When I run these plug-in directly from eclipse (right click on project->run as->eclipse application), it works fine. But when I use export wizard and export both plug-in as jar, and put these jars in eclipse's plug-in directory and run eclipse, my plug-in with Extension can't find interface of the plug-in with Extension-Point.
What is wrong I am doing?
Thanks for your consideration.
Re: How to Export Dependent Plugins in Eclipse [message #903328 is a reply to message #903321] Thu, 23 August 2012 03:59 Go to previous message
No Message Body
Previous Topic:OSGi
Next Topic:can't start OSGi need help
Current Time: Sat Jul 19 22:40:09 EDT 2025
Powered by FUDForum. Page generated in 0.06448 seconds
