Home » Eclipse Projects » Rich Client Platform (RCP) » Eclipse RCP errors(Eclipse RCP errors)
Eclipse RCP errors [message #902936] Tue, 21 August 2012 06:15 Go to next message
Please kindly help me below is my errors and Please I need sample config file also.
Eclipse for RCP and RAP Developers,Version: Juno Release,Build id: 20120614-1722
!SESSION 2012-08-21 15:11:22.642 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0
Framework arguments: -product ESC_Configurator_Tool.product
Command-line arguments: -product ESC_Configurator_Tool.product -data E:\Explorer/../runtime-ESC_Configurator_Tool.product -dev file:E:/Explorer/.metadata/.plugins/org.eclipse.pde.core/ESC_Configurator_Tool.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-08-21 15:11:24.495
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.addons.swt/org.eclipse.e4.ui.workbench.addons.cleanupaddon.CleanupAddon
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-08-21 15:11:24.496
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.addons.swt/org.eclipse.e4.ui.workbench.addons.dndaddon.DnDAddon
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-08-21 15:11:24.497
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.addons.swt/org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2012-08-21 15:11:24.962
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.Error: Unresolved compilation problem:
FileProperties cannot be resolved or is not a field
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:81)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:72)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1249)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1221)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:924)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:133)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:684)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1664)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2145)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4525)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:231)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1217)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:710)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:639)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:725)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:696)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:690)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:675)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:961)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at esc_configurator_tool.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.Error: Unresolved compilation problem:
at esc_configurator_tool.UpdateProperties.setUpdates(UpdateProperties.java:32)
at esc_configurator_tool.ApplicationWorkbenchWindowAdvisor.preWindowOpen(ApplicationWorkbenchWindowAdvisor.java:42)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpening(WorkbenchWindow.java:1209)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:508)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 53 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-08-21 15:11:24.965
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@7041e3 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {MSI's ESC Configuration Generator}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@49436a, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 200, y: 200, width: 1024, height: 768)
!STACK 0
... 53 more
Re: Eclipse RCP errors [message #903200 is a reply to message #902936] Wed, 22 August 2012 09:36 Go to previous messageGo to next message
this looks very weird? Why don't you check your target configuration and
your run configuration. Your run configuration must not contain any
erroneous plug-ins in your wokspace. That means you have to close the
org.eclipse.e4.ui.workbench.swt plugin if it is in your workspace and
select the one from the target platform ...
Am 21.08.2012 12:15, schrieb RP Mar:
> file also.
> 20120614-1722
> java.version=1.7.0
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> compilation problem: FileProperties cannot be resolved or is not a
> field
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> at
> at
> at
> ... 53 more
> mailto:org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@7041e3
> mailto:org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@49436a,
> !STACK 0
> field
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 53 more
Re: Eclipse RCP errors [message #903513 is a reply to message #903200] Fri, 24 August 2012 00:33 Go to previous message
Please I created Target definition Eclipse RCP SDK3.5.2 and check the run configurations main:- Run a product,
java executable default,plug-ins:-Workspace,ESC_Configurator_Tool,select the check box for Include optional dependencies,add new workspace plug-ins...
Please here is below error...
Message:-Exception launching the Eclipse Platform:
Plug-in org.eclipse.equinox.launcher
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:626)
Please kindly exact config.ini file here.
#This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
#Thu Jun 14 14:22:50 EDT 2012
org.eclipse.update.reconcile=false
eclipse.p2.profile=epp.package.rcp
osgi.instance.area.default=@user.home/workspace
osgi.framework=file\:plugins/org.eclipse.osgi_3.8.0.v20120529-1548.jar
equinox.use.ds=true
eclipse.buildId=I20120608-1400
osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.0.300.v20110815-1744.jar@1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
eclipse.product=org.eclipse.platform.ide
osgi.splashPath=platform\:/base/plugins/org.eclipse.platform
osgi.framework.extensions=
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.p2.data.area=@config.dir/../p2
osgi.bundles.defaultStartLevel=4
Previous Topic:config.ini, Exception launching the Eclipse Platform
Next Topic:Is there a UI to register xmlns:myownmodel to extend e4 application model
Current Time: Sun Jul 20 16:14:48 EDT 2025
Powered by FUDForum. Page generated in 0.05071 seconds
