Need help viewing applet in Eclipse [message #903103] |
Tue, 21 August 2012 22:32  |
I developed an applet outside of Eclipse using notepad for the .java and .htm files. It runs fine using the JDK appletviewer from the command line. However, I have imported the files into an Eclipse project. When I choose Run As > Java Applet the default window that pops up is too small to show the entire applet. Resizing the window just shows additional white space. Is there a way to set the default size of the Eclipse applet viewer so I can see my entire applet? I am doing this to save time from having to save changes, re-compile, and re-launch the applet from the command line which is a simple click of the mouse in Eclipse. Thanks for any help.
FUDForum. Page generated in 0.03180 seconds
