Home » Newcomers » Newcomers » Eclipse Not opening(Please Help)
Eclipse Not opening [message #902712] Mon, 20 August 2012 00:08 Go to next message
Eclipse will not open on my Ubuntu 12.04 32 bit system...I have Java 7 installed. Here is what is says when I try to open it:
JVM terminated. Exit code=13
/usr/bin/java
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-jar /home/tcms2330/Downloads/eclipse//plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
-os linux
-ws gtk
-arch x86
-showsplash /home/tcms2330/Downloads/eclipse//plugins/org.eclipse.platform_4.2.0.v201206081400/splash.bmp
-launcher /home/tcms2330/Downloads/eclipse/eclipse
-name Eclipse
--launcher.library /home/tcms2330/Downloads/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.200.v20120522-1813/eclipse_1502.so
-startup /home/tcms2330/Downloads/eclipse//plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.overrideVmargs
-exitdata 4ac000d
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx512m
PLEASE HELP
Re: Eclipse Not opening [message #902719 is a reply to message #902712] Mon, 20 August 2012 02:21 Go to previous messageGo to next message
Are you sure your Java7 is also 32bit? What does java -version tell you?
Tom
Am 20.08.12 06:08, schrieb Travis Stanley:
> /usr/bin/java
> -Xms40m
> -Xmx512m
> -jar
> -os linux
> -ws gtk
> -arch x86
> -showsplash
> -name Eclipse
> --launcher.library
> -startup
> -exitdata 4ac000d
> -vm /usr/bin/java
> -vmargs
> -Xms40m
> -Xmx512m
> -jar
> PLEASE HELP
Re: Eclipse Not opening [message #1800513 is a reply to message #902719] Mon, 31 December 2018 08:38 Go to previous messageGo to next message
Hi, You can check the below links
https://stackoverflow.com/questions/27019786/eclipse-java-was-started-but-returned-error-code-13 and https://javahungry.blogspot.com/2018/10/solved-java-started-returned-exit-code-13-error-eclipse.html
Hope this helps.
Re: Eclipse Not opening [message #1823225 is a reply to message #1800513] Mon, 23 March 2020 04:01 Go to previous message
This is a helpful resource
Previous Topic:Failed to create the Java Virtual Machine
Next Topic:Failed to create the Java Virtual Machine.
Current Time: Sat Jul 19 16:49:22 EDT 2025
Powered by FUDForum. Page generated in 0.10472 seconds
