E4 @Named dependency injection and OSGi services [message #902056] |
Wed, 15 August 2012 12:49  |
Hi everybody,
I am trying to do the following without luck: I am writing a bunch of
OSGi plugins that will provide services that will be used in an E4
application.
I have an interface IStorage that is implemented by different plugins,
each one providing a particular type of storage (e.g., local, remote, etc.)
Now, I would like to be able to choose the particular "type" using
@Named annotations, something like
@Inject
@Named("remote")
IStorage remoteStorage
The problem is that I cannot make it work.
In my pure OSGi plugin I've tried the following:
1) Creating a declarative service that provides the IStorage interface
and whose name is "remote".
2) Getting an Eclipse context in my plugin's activator using
EclipseContextFactory. getServiceContext(bundleContext); and putting the
"remote" implementation in it using context.set("remote", new
RemoteStorage())
They both don't work.
So the question is: is it possible, in a pure OSGi world, to use E4 DI
to provide different services implementing a given interface and
selecting them using the @Named annotation?
Fabio
P.S.: Registering a service using bundleContext.register(IStorage.class,
new RemoteStorage(), null) works perfectly when I try to @Inject
IStorage somewhere. The problem is that in this way I cannot select one
implementation when multiple ones are available.
Re: E4 @Named dependency injection and OSGi services [message #902143 is a reply to message #902056] |
Thu, 16 August 2012 02:30   |
No - e4 DI will always pick the first one it finds. The @Named
annotation will simply make the DI container search for a key "remote"
instead of "IStorage.class.getName()"
You could invent you own annotation which searches the OSGi-Service
registry differently.
So you'd write:
@Inject
@OSGiNamed("remote")
Tom
Am 15.08.12 18:49, schrieb Fabio Mancinelli:
> Hi everybody,
> application.
> @Inject
> @Named("remote")
> RemoteStorage())
> Fabio
Re: E4 @Named dependency injection and OSGi services [message #902249 is a reply to message #902143] |
Thu, 16 August 2012 10:11   |
Thanks Tom for your reply.
What you said was clear to me. It was just the I thought that the @Named
annotation, somehow, affected also the way the OSGi services were searched.
As Lars suggested maybe a feature request here makes sense because
since OSGi declarative services have a provided interface and also a
name, this perfectly fits the use case
@Inject @Named("component-name") ProvidedInterface service;
Fabio
> So you'd write:
> @Inject
> Tom
>> Hi everybody,
>> application.
>> @Inject
>> @Named("remote")
>> RemoteStorage())
>> Thanks,
>> Fabio
FUDForum. Page generated in 0.07668 seconds
