Home » Modeling » EMF » Metamodel hierarchies / model layers
Metamodel hierarchies / model layers [message #901796] Tue, 14 August 2012 11:41 Go to next message
how can I store model instances of ecore models?
To be more specific: I wonder how I would store an UML object diagram (runtime-instances), that is typed over a given UML class diagram.
The class hierarchy would look like this:
M3: Ecore model defined in an .ecore file
M2: UML model defined in an .ecore file
M1: Domain model defined in an .uml file
M0: Instance model defined in an ??? file
In other words: I want to create dynamic instances of UML like it can be done in Ecore and store it into a file.
Simon
Re: Metamodel hierarchies / model layers [message #901803 is a reply to message #901796] Tue, 14 August 2012 11:52 Go to previous messageGo to next message
Comments below.
On 14/08/2012 5:41 PM, Goood Guy wrote:
Using resources as explained in the introductory overview.
I can't parse this "typed over" phrase.
UML doesn't directly provide a way to create instances.
UML doesn't support that. You can convert your UML model to an Ecore
model (like the UML2 importer does) and then create instance of that.
> Regards,
> Simon
Re: Metamodel hierarchies / model layers [message #901944 is a reply to message #901803] Wed, 15 August 2012 04:41 Go to previous messageGo to next message
With "typed over" I mean that the model instance is compliant to its metamodel, i.e. the single class instances have a type from the metamodel.
I know that I can convert an UML model to an Ecore model, but I was wondering if EMF has a mechanism that support several model layers / the instantiation of metamodels (uncoupled from UML).
Re: Metamodel hierarchies / model layers [message #901953 is a reply to message #901944] Wed, 15 August 2012 05:46 Go to previous message
EMF has support for the Ecore model and creating instances that conform
to an Ecore model. Any other model, such as UML2, must provide a way to
create instances based on semantics that only the model implementer can
possibly know.
> metamodel.
Previous Topic:Handle more than one editor plugin
Next Topic:Overriding standard ECore validation messages
Current Time: Sun Jul 20 04:26:42 EDT 2025
Powered by FUDForum. Page generated in 0.04010 seconds
