Home » Modeling » EMF » [Xcore] Ecore Diagram problem
[Xcore] Ecore Diagram problem [message #901771] Tue, 14 August 2012 10:01 Go to next message
Hi all,
Although I prefer creating models with the Xcore editor, for showing the model to the colleagues a graphical representation is more suitable.
I can not use the "Initialize Ecore Diagram File ..." context menu for an Xcore file, but can get a diagram by creating a .ecorediag file with the following content:
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.2/notation" xmi:id="_d3eUYOYWEeG0J45nAFRXEg" type="EcoreTools" name="DefaultName" measurementUnit="Pixel">
  <styles xmi:type="notation:DiagramStyle" xmi:id="_d3eUYeYWEeG0J45nAFRXEg"/>
  <element xmi:type="ecore:EPackage" href="mymodel.xcore#/EPackage"/>
</notation:Diagram>
i.e. replacing the package reference
href="mymodel.ecore#/"
with
This works for simple cases. The issue I ran into is that when I specify a directory for the generated edit files, the diagram editor can not be loaded any more:
@GenModel(editDirectory="/com.ck.mymodel.edit/src-gen")
package com.ck.mymodel
class Data
// content
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting(TransactionChangeRecorder.java:348)
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.appendNotification(TransactionChangeRecorder.java:302)
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.processObjectNotification(TransactionChangeRecorder.java:284)
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.notifyChanged(TransactionChangeRecorder.java:240)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.emf.codegen.ecore.genmodel.impl.GenModelImpl.setEditDirectory(GenModelImpl.java:4438)
	at org.eclipse.emf.ecore.xcore.resource.XcoreModelAssociator.installDerivedState(XcoreModelAssociator.java:130)
	at org.eclipse.xtext.resource.DerivedStateAwareResource.installDerivedState(DerivedStateAwareResource.java:125)
	at org.eclipse.xtext.resource.DerivedStateAwareResource.getContents(DerivedStateAwareResource.java:48)
	at org.eclipse.emf.ecore.util.EContentAdapter.setTarget(EContentAdapter.java:230)
	at org.eclipse.emf.ecore.util.EContentAdapter.setTarget(EContentAdapter.java:186)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapterList.didAdd(BasicNotifierImpl.java:121)
	at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList.java:419)
	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:301)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapterList.add(BasicNotifierImpl.java:193)
	at org.eclipse.emf.ecore.util.EContentAdapter.addAdapter(EContentAdapter.java:346)
	at org.eclipse.emf.ecore.util.EContentAdapter.setTarget(EContentAdapter.java:249)
	at org.eclipse.emf.ecore.util.EContentAdapter.setTarget(EContentAdapter.java:190)
	at org.eclipse.emf.ecoretools.diagram.part.EcoreDocumentProvider$ResourceSetInfo.<init>(EcoreDocumentProvider.java:745)
	at org.eclipse.emf.ecoretools.diagram.part.EcoreDocumentProvider.createElementInfo(EcoreDocumentProvider.java:90)
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.document.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:387)
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.doSetInput(DiagramDocumentEditor.java:460)
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.setInput(DiagramDocumentEditor.java:423)
	at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEditor.java:346)
	at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init(DiagramEditor.java:653)
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.init(DiagramDocumentEditor.java:126)
	at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:828)
Is this a problem on the editor side and should not try to use it this way?
Thank you in advance,
Csaba
Re: [Xcore] Ecore Diagram problem [message #901798 is a reply to message #901771] Tue, 14 August 2012 11:47 Go to previous messageGo to next message
Comments below.
On 14/08/2012 4:01 PM, Csaba Koncz wrote:
> Hi all,
> suitable. I can not use the "Initialize Ecore Diagram File ..."
> </notation:Diagram>
> i.e. replacing the package reference href="mymodel.ecore#/" with
> class Data
> // content
> write transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
That does this:
protected void setTarget(Resource target)
basicSetTarget(target);
List<EObject> contents = target.getContents();
for (int i = 0, size = contents.size(); i < size; ++i)
Notifier notifier = contents.get(i);
addAdapter(notifier);
So I guess the problem is that the adapter is added first and then
getContents computes the stuff that "nobody is supposed to have seen
yet", but because there is already an adapter attached, it sees the
results being added, and starts listening to them, and then see what
looks like a modification. I'm not sure how best to solve that. We
could add the adapter later, or perhaps we should be adding the contents
while suppressing notifications. I'll need to talk to the Xtext guys
given this is a problem any Xtext resource could also have. Please open
a bugzilla with a simple test case and I'll have a look.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> way?
> Csaba
Re: [Xcore] Ecore Diagram problem [message #956138 is a reply to message #901798] Wed, 24 October 2012 05:14 Go to previous message
Opened bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=392725
Previous Topic:[CDO/Hibernate] Exporting Hibernate Mapping
Next Topic:Enabling OPTION_USE_XMI_TYPE fails
Current Time: Sun Jul 20 16:03:07 EDT 2025
Powered by FUDForum. Page generated in 0.03722 seconds
