Home » Eclipse Projects » Remote Application Platform (RAP) » Change 404 error page when deploy with Jetty inside Equinox (How to add a custom error page to a web application)
Change 404 error page when deploy with Jetty inside Equinox [message #900879] Wed, 08 August 2012 15:26 Go to next message
I have seen how to do this when depoloying a WAR file:
<servlet-mapping>
<servlet-name>equinoxbridgeservlet</servlet-name>
<url-pattern>/app/*</url-pattern>
</servlet-mapping>
<error-page>
<error-code>404</error-code>
<location>/error404.html</location>
</error-page>
How can we do something similar when deploying the web server inside the OSGi runtime (Equinox + Jetty + RAP + your app). I am deploying into a Virgo-tomcat server. Can I configure the custom error page in the config.ini there?
Re: Change 404 error page when deploy with Jetty inside Equinox [message #901566 is a reply to message #900879] Mon, 13 August 2012 08:56 Go to previous messageGo to next message
George,
the plain HttpServer has no support for web.xml, hence custom error
pages won't work.
Virgo however may have support for this. You should ask this question on
the Virgo forum.
Rüdiger
> <servlet-mapping>
> </servlet-mapping>
> <error-page>
> </error-page>
> config.ini there?--
Rüdiger Herrmann
http://codeaffine.com
Re: Change 404 error page when deploy with Jetty inside Equinox [message #902440 is a reply to message #901566] Fri, 17 August 2012 11:09 Go to previous messageGo to next message
Thanks for the reply. Will look into another way to configure this. Regards, GEorge
Re: Change 404 error page when deploy with Jetty inside Equinox [message #907137 is a reply to message #902440] Mon, 03 September 2012 07:09 Go to previous message
You could try to replace the http service that comes with Equinox/Jetty with the implementation from
http://team.ops4j.org/wiki/display/paxweb/Pax+Web
They are providing an extended http service that allows the registration of customized error pages and other insteresting things:
http://team.ops4j.org/wiki/display/paxweb/Error+Pages
Maybe this helps to solve your problem...
Previous Topic:rap viewpart not close all
Next Topic:Undo in IE
Current Time: Sun Jul 20 14:22:07 EDT 2025
Powered by FUDForum. Page generated in 0.25024 seconds
